The FSTT tournament.
quote:
OK. You need to do PTT style stats
Okay.
Clone
Shape: Box
Colour: White. Has shades painted on the front.
Speed: 100mph
Weight: 100kg
Armour: 4mm cardboard
Drive: 2 custom-made motors weighing 10kg, giving it 200hp.
Power: 4 custom-made batteries weighing 2kg each, powering power for up to 10 years, and minimum power 1 year.
Wheels: 4 wheels made up taped up CDs with rubber on the edges.
Ground Clearance: 10mm
Dimensions in CM: 70cm^3
Weapons: Its coolness makes its opponents explode, and if that doesnt work hell just run into you and kill you.
Srimech: None
Strengths: Its cool!
Weaknesses: Overconfidence.
:proud:
Its gotta be realistic. Pretend Im not running it, pretend say AJs running it.
B-but...b-but it IS realistic! The motors are custom-made! The batteries are custom made! With cardboard armour it CAN have dimensions like that for a box!
Come on! :sad: ffffff>(note the sarcasm in the smiley)
(Message edited by kodster on January 27, 2008)
Kody its as realistic as Jason Voorhees joining the EU. I suggest you make it more suitable for sumo ring fighting. Mainly flippers and axes and spinners.
whats up with the different weapon rule Tim?
am I right in thinking a 50 kg vertical bar is different to a 40 kg vertical disc?
Okat, PTT style stats:
Shiny Happy People
Shape: Box with Wedge
Colour: Mirror
Speed: 5mph
Weight: 99kg
Armour: 10mm corrugated fiberboard attached to a wooden chassis, but with some shiny old Robbie Williams CDs attached to the outside, so it looks like a mirror
Drive: 4 wheel drive with 4 Ford windscreen wiper Motors @ 12 volts
Power: Some 12 volt battery packs.
Wheels: 4 wheels
Ground Clearance: 2cm, but zero at the front
Dimensions in CM: 50 x 50 x 20
Weapons: Shiny Wedge
Srimech: None
Strengths: Its shiny!
Weaknesses: Its Shiny!
Name - Hundreds of Thousands
Colour - Unpainted
Shape - Each is a little wedge
Weight - 99.9kg in total
Speed - 20 mph
Armour - Nothing
Motors - Antweight Motors with 2 wheels at the rear, powered by antweight batteries.
Weapons - Nothing
Ground Clearance - 3mm
Notes - 665 automatic 150g antweights with a wedge
Strength - You try working out when 333 are knocked out
Weaknesses - Easy to destroy
Name - The Flying Machine
Shape: Cone with outriggers
Colour: Grey, with invisibility paint, makes it hard to see
Speed: Depends which way its flying, but up-to 20 mph
Weight: 90kg
Drive: Flys
Power: Some weird method in which it can fly and dance in the air to come into attack
Wheels: It has wheels?
Ground Clearance: 0mm to 20000mm
Dimensions in CM: 50cm^3
Weapons: Bottom mounted spinning disc, and some more spinning discs thrown in for good measures
Srimech: It will right itself by flying
Strengths: Can attack from a number of angles
Weaknesses: Cant attack from the ground up though
Realies:
Shunt (with a bit less armour)
Roadblock
Bodyhammer
The different weapon rule is no 2 robots of yours can share the same weapon.
UNFAIR :sad:
*fits tiny flail to rear of shiny happy people*
I dont really care about you Tim but I have to say... you got guts for starting one! I am so convinced that I shall be entering too! :proud:
Shape: Humanoid-like
Colour: Fleshy
Speed: 5mph
Weight: 250kg
Armour: Flesh and fat.
Power: Food.
Motivation: 2 legs
Ground Clearance: 5mm at the tips of the feet, 0mm everywhere else
Dimensions: 60cm x 100cm x 160cm
Weaponry: Flamethrower that only works when it wants to, and it doesnt
Srimech: Can get up like a human does
Strengths: None
Weaknesses: The letter W.
