can you buy allen key attachments for drills?
yes they come with sets or on there own
try these
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=34154&doy=2m1http://www.maplin.co.uk/Module.aspx?...=34154&doy=2m1
If you can get to the underside of the bolt, drill it from there. Drilling from below has the same effect as a left hand drill and will will spin the stuck bolt out.
does a left hand drill just mean a drill in reverse?
yes
but drilling in reverse with a normal ll bit wont work as the edges wont dig in, thats hy it might be worth a try from behind. Does it stick out behind very much?
its always worth trying from behind!
not at all, it goes into box section, no way of seeing it at all
Not just easier to grind it flat, fit another ?
