ah i see, so it is essentialy a heavy weight version of Hazard?
Yeah, close to an up scaled Hazard. but much more hardcore, and made by a different team.
1. SOR (andy)
2. Hypertension (matt)
3. Disctruction (aaron)
4. Kody vapour
5. Die-Ceratops Re-Invertus (chris)
6. Salamander (alex)
1. Gravity (andy)
2. Plunderbird 2 (matt)
3. [Brutality(aaron)]
4. Terrorhurtz (kody)
5. therimdor 2 (chris)
6. Razer (alex)
Im busy atm, count me in!
1. Metal Sonic Spin Dash
SHAPE- low skirted box, with fixed front wedge & sloped sides
COLOUR- blue bodywork, with red-and-white striped skirting
WEIGHT- about 100kg
DIMENSIONS- 102cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at front with spatula, 0mm elsewhere with skirts, 12mm elsewhere without skirts
ARMOUR- 3.75mm Hardox
WHEELS- inside robot, 6WD
POWER- 2 x LEM-130 MagMotors. These will run at 36v and produce approximately 18hp.
WEAPONS- The main weapon here is really the excellent traction, but like all its other incarnations, Spin Dash still maintains its Pussycat-style vertical saw blade, running at 3000rpm. This time, however, the four-clawed spinner sticks halfway out of the front wedge, so that when the wedge/spatula combo bashes underneath an opponent, both the wheels and the underbelly are at the mercy of the saw.
Also features several Mute-style barbs on top to hook onto other robots and let me drag them around the ring
SRIMECH- a rear-hinged arm on top with a basic low-pressure CO2 set-up. Can be used to about 30-40 times and is ONLY used for self-righting in order not to waste the gas supply
NOTES- flies the Scotland flag (though, forgot to add to pic. Shockaroonie!), has F*** Shadow! written on the underbelly in red
STRENGTHS- excellent traction, fast, manoueverable, tough armour, well-skirted, great at getting under everyone else
WEAKNESSES- so-so turning ability, teething troubles?
PICTURE- http://img77.imageshack.us/img77/3603/fifthspindashde6.pnghttp://img77.imageshack.us/img77/360...pindashde6.png
2) Behemoth (RW7)
Meh, my biggest All Star is Flick of the Wrist most likely :proud:
http://strickenone.proboards99.com/index.cgi?board=thvapours&action=display&thread=11 66283536http://strickenone.proboards99.com/i...n=display&thre ad=1166283536
For my realie... Nightmare please :proud:
Wedginator 5.0 will be my vapourbot, came 3rd in FFW1 and 7th in FFW4 (but was seeded 9th in FFW5). :proud:
http://strickenone.proboards99.com/index.cgi?board=heavies&action=display&thread=1145 103447http://strickenone.proboards99.com/i...display&thread =1145103447
Entries (so far)
1. SOR (andy)
4. Wedginator 5.0(Kody)
7. Flick Of The Wrist (Martijin)
8. Metal Sonic Spin Dash (Steve)
1. Gravity (andy)
3. Brutality (aaron)
6. Razer (alex)
7. Nightmare (Martijin)
8. Behemoth (Steve)
Stats in tonight Martyn.
Martyn has asked me to post this since his net is being a bloody b****** right now:
quote:
can people please post there stats or tell me where to find them so I can post the draw thank you
