Hi Adrian
I use a Spectrum, my dip switch settings are 1 off, 2 on, 3 on, 4 off, 5 on, 6 off, this works on mine to gige steering on one stick, throttle on the other.
Hi Adrian
sorry about the typo, gige should read give.
cheers dave, i copied your settings and its close now. when i press forward and backwards only the left motor is working. when i press left or right the other motor is working. all my mixing is turned off, as i thought these speedos mix themselves.
Edit: Incorrect info.
(Message edited by kane on December 10, 2007)
Turn switch 4 on.
cheers kane, will give that a try. so i presume i leave the mixing on the spektrum off?
Ive found it easiest to let the speed controller do the mixing, and not to use the Spektrums.
However without mixing i couldnt set my Dual Rate, anyone else have this problem?
dual rate, :crazy:, your getting too tech for me LOL. does switching 4 on turn on the mixing?
Dual rate is that I effectively have 2 speeds, based on % of the stick.
So with the switch on 0 I have for instance 50%, and on 1 100%. I then normaly drive on 50% making it easier to manouvre and aim, but when I then need to push or need more speed, I can switch up to 100%.
Sometimes on very slippery arena floors (GRA) Ive even driven on 30% just so I could aim.
oh i see!, on my spektrum you can adjust the trim plus and minus percentage is that what you mean? its these technical phrases that confuse me lol
(Message edited by ady on December 10, 2007)
