isnt that the setup i sold you about 2 years ago with everything apart from the co2 bottle??
yes, ive been meaning to get it going but it just hasnt happend :sad: ive got loads of motors, speed controllers, raido stuff etc. Just never had the flipper parts sorted, now ive got a few extra quid i want to do it, waste otherwise, and now with more and more local events taken place i really want to get into it.
Pressure ratings are usually 10 bar.
You have a ram ...
Youll need a buffer tank together with a 5/2 or 3/2 valve (double acting OR single acting cylinder ) all rated @ 10 bar or more to go with your co2 cylinder,regulator and pressure relief valves one High pressure ( 1000psi) and one low pressure.
Make a weight guesstimatiion before buying everything .....you may find it difficult to get down to the 12kg limit.
(Message edited by woody on June 16, 2007)
do you have any more setups ready to sell kenny?:)
only a 10 tonne heavyweight setup which is too powerful!!! :)
daniel has a 5/2 high flow 3/8 valve which was in thor on robot wars, a festo buffer, regulator, ram everything part from the co2 bottle, just get a 9 or 12oz paintball bottle
was a good setup in testing got alpha bout 7ft in air
(Message edited by teamkenny on June 16, 2007)
