Advice on betteries please...
Rather than start a new thread, im looking to replace my batteries in Conundrum Mk2 before the champs, what do people recommend I get and where from. Keep in mind that I am running a hungry Ev warrior and a couple of drill motors, at the moment it seems to run ok on two heavy 3Ah 12v BotPacks, just want an upgrade.
Chris - ^_^
I am having a problem charging my batteries . I have a modified PSU and a Pro Peak constellation charger . When ever i want to charge my 3300mah 24v pack at anything over 2 amps i get an error message saying Input Voltage 11.60v Is there a solution to this ?
get a better powersupply, the amps drawn from the PSU make the voltage sag beneath the minimum value of the charger hence the error
Thanks alot Tim , Does anybody know any good power supply units ?
We had this problem with three different power supplies that we tried. In the end bit the bullet and bought a big one from Rapid Electronics. Many teams use the same one. (order code was: 85-1828) Cost about £110 inc del.
Chris stick with the botpacks if you can otherwise, race packs/indivual cells, if your confident of making up good packs, of GP3700 NiMH
If you go to chargers and PSUs at http://www.technobots.co.ukwww.technobots.co.uk - both the 13.8v 20amp Power supply (1090-016) and the 13.8v 20A Dual Output Power supply (1090-017) are both ideal not to only run 1 of your chargers at MAX ratings, but attualy 2. I think they say you need about 8 or 9amps supply to each charger for it to work to its max. So a 20amp supply will quite happily do 2 chargers. And the cheaper one at £34.12 which i use, does one charger perfect, and also ran 2 chargers without problems when people borrow the supply from me as well. LOL - *COUGH* Pete/Jonno *COUGH*.
Mr Stu
We use one of the 40A power supplies - theyre £136 plus delivery from Technobots (so about £140) but you can get the same charger from Rapid Electronics for £109 including free delivery
Link on the Rapid website is
http://www.rapidonline.com/productinfo.aspx?kw=85-1828&tier1=Electrical%2B%26%2BPower&tier2=Power%2B Supplies&tier3=Switch%2BMode%2BPSUs&tier4=25A%2f40 A%2BSwitch%2Bmode%2Bpower%2Bsupplies&moduleno=6506 3http://www.rapidonline.com/productin...rical+%26+Powe r&tier2=Power+Supplies&tier3=Switch+Mode+PSUs&tier 4=25A%2f40A+Switch+mode+power+ supplies&moduleno=65063
Weve had ours for around 3 years now without any problems.
Ed
Ed I wish you had put that post on here 2 weeks ago :)
Sorry Gary - if its still 7 days from the day after they were delivered to you then you can always cancel your order (Distance Selling Sale of Goods Act) however if its after then theres nothing you can do :sad:
Sorry !
Ed
