Not worth it, go for Electronizes or similar instead
did you tried both numbers?
1- 01428 727825
2- 01795 427614
let me know
thanks yoeri
Rung 01795 427614 1st. They put me onto 01428 727825. They said they have nothing now to do with it and the speed controller has not been made since 2002.
I agree with Ewan. Ive got Electronize and they are very easy to use.
(Message edited by armadrillo on May 30, 2006)
ok...
thanks for helping everyone...:wink:
Yoeri, a interesting speed controller for roboteers may be found on the DRG forum.
http://www.dutchrobotgames.nl/forum/viewtopic.php?t=748http://www.dutchrobotgames.nl/forum/viewtopic.php?t=748
Available in Holland, may wel be worth it.
Yoeri, There are lots of small speed controllers out there. I prefer Electronize but M.Sonik controllers also work. Both can be plugged directly into a receiver. Technobots carries the Electronize controllers (and some others). For about 40 pounds you can have two channels of control, one for each motor, which will do the same job as the Rex controller. Good luck with your build.
More reliable aswell, Lots of people had problems with rexs controllers. If your using Wiper motors get the 15amp CPU vershions.
I do not disagree with you, but the problem is and always is that Technobots doesnt deliver to holland anymore. Thats why I referred to the DRG site.
If you dont get the speed controllers you want from a Dutch source then you could go to the Electronize website and order directly from them. As far as I know they will ship to the Netherlands.
so if i buy a electronize 15 amp controller i can do the same whit it as whit the controller from rex...
