New Roboteer
thanks ewan my brother has already checked it out for Psycho Fling (Its a good shop)
What do you think of instead of using the batteries from a drill I could use Nicads. there cheap and my brother uses them aswell so hell know what to do if anything goes wrong!
William
New Roboteer
Drills mainly use Nicads anyway, but usually cheap ones with low capacity and high internal resistance, you would get noticably better performance out of Nicads designed for models, we use http://www.overlander.co.ukhttp://www.overlander.co.uk for most of ours. Their website states clearly how much current you can get out of them. I didnt concider good Nicads cheap though, we need a new set for the Heavyweight but 90 sub C cells arent cheap, overlander has them at £4.50 each.
New Roboteer
william, if you are starting out, drill batteries are perfectly adequate to run drill motors for a good 20 minutes or so.
I think people dont give them the credit they require.
If you are using high power motors like golds or astros, you will notice a problem though.
New Roboteer
I agree,,,,
Keep costs to a minumum, get started and then you can make improvements.
Push and Shove, the polycarb 4wd box, which i built for andrew, runs on drill motors, and drill batteries to keep the cost down for him, and does very well.
John
http://www.roamingrobots.co.ukwww.roamingrobots.co.uk
New Roboteer
can I hav ppls msn adress plz
william (if u dont mind)
:lol:
New Roboteer
Im hardly the most experienced person to ask about anything, but feel free to add me.
ajj14590(at)gmail.com [replace the (at) with an @]
New Roboteer
maddox10(ad)hotmail(dot)com
