Hmmm, try changing/removing the fuse as it could be blown. Alsy try by passing the power switch (temporarily) as the problem could be with the switch.
Okay thanks. I will try bypassing the power switch but I know the fuse isnt blown.
Im still not gettting any movement from my motors. I tried pluggin a servo in one of the other channels in the receiver and it worked. But I get no repondse from inputs 1,2 from the Vantec to the receiver. That means the receiver is properly working, the only thing I can think of is the Vantec inputs (1,2) are not working.
was the vantec brand new or second hand?
The vantec and all the other components are brand new.
Borrow someones radio gear and try again?
Take one of the connectors out of channel 1 or 2 and try a servo in those channels to ensure they are working.
I already tried taking the connector out of channel 1 and putting in a servo and it worked. So I can only think that the Vantecs inputs must not be working because the transmitter and receiver definitely are functioning.
