Most Insane Robotic Elimination Challenge!
Flaming Hell
Weight: 100kg
Dimensions: 90x90x60 cm
Weapon: a triangular spinning cage with 3 sharpened bot openers on each end, weighing 5kg each, spinning at 3000 RPM, powered by a Lemco on 36v
Power: 2x Bosch 750 motors at 24v (its been made so that the cage motor gets 36v but the drive only gets 24, as the drive is ok as it is on 24V)
Shape: circular base with triangular cage atop
Speed: 15mph
Drive power: 4bph
Notes: small electric actuators in the rotor arms in order to self right. They have been shock proofed so that the weapon impact will not bust them, and the cage spins 2mm from the ground. Small bearings for the cage and the far set apart wheels give it increased stability for a FBS
Turning Circle: 0cm
Armour: 3mm titanium
Wheel Type - 4 small wheelbarrow type wheels (no need for great traction)
Strengths: Power of cage
Weakness: Unpredictable bounce off from an opponent
Hell Machine
Weight: 100kg
Dimensions: 140x100x60 cm
Weapons: Lemco motor powered axe (run through gear box) that can deliver an axe blow of 3 tons (according to my calculations) and rear linier actuator operated lifting arm that can flip 600kg
Srimech: Side arms and rear arm
Speed: 15mph
Transmission: a 4 wheeled Tornado set up(36v and same gearing), but with a pair of Mag C40€™s in place of the Bosch motors, and a set of NiMh in place of the heavy Lead Acids the real thing uses.
Turning Circle: 0m
Ground clearance: 0 at the scoop and wedge edge, 2mm the rest of the way around
Wheel Type: Go-kart
Body Shape: scoop fronted, wedged back
Armour: 8mm Grade 5 Titanium and 2mm stainless steel
Colour: Black with flame face on scoop and name in blood writing on side, devil head on rear wedge
Strengths: Enormous pushing power (About 12hp), EXTREMELY powerful axe, relentless in attacking (until a robot is immobile)
Weakness: Dislikes spinners, doesnt like weapons that use carbon
Weight: 100kg
Dimensions: 150cm x 80cm x 120cm
Shape: low angled box with disc on the front like 13 black and rear 259 disc, style
Weapons: A front mounted Horizontal spinning disc and a rear mounted vertical spinning disc, both running at 4500rpm and delivering a blow of 75kj
Top Speed: 13 mph
Transmission: 4 Rubbertex coated aluminium wheels (Rubbertex is a grippy rubber substance used on the K*bot tables) run on a Smidsy type wheel system, and run by a pair of Bosch 750€™s and a bank of Ni-cads to give me more weight for armour
Armour: 8mm Titanium
GC: 3mm either side and back, 7mm under the disc at the front, variable at the sides of the disc
Srimech: powerful electric arms mounted on the top
Turning Circle: 0cm
Strengths: devastating weapons
Weakness: carbon based weapons
Notes: will NEVER turn the vertical flywheel into an opponent as it will throw SH over. Also, counter-acting discs (vertical and horizontal) will keep it stable, and if it is flipped, it does a funny jig in the air before coming down, most of the time, right way up
Dimensions: 120cm x 80cm x 40cm
Weight: 100kg
Shape: steep wedge front, elongated wedged tail (not used as a weapon)
Weapon: 1000psi 2 pivot pneumatic flipper that can generate enough momentum and force to throw a 100kg robot 25ft up and 20ft across
Top speed: 18mph
Transmission: just like Razer€™s
GC: 0 at the front, 2mm down the side, 4mm at the back end
Turning Circle: 0cm
Armour: 6mm aluminium and steel alloy
Strengths: Can win with one weapon shot
Weakness: None
Notes: 4 wheels, the rear two of which are Razer type, so the flipper is always facing its opponent
Name: Jaws of Hell
Weight: 100kg
Dimensions (LWH): 130 x 100 x 25 cm
Body shape: Tornado shaped, but with 6 wheels
Weapons: a hydraulic tearer. The idea is that the large blade that is edged on both sides punctures the armour of an opponent, and a 3000psi hydraulic ram separates them, causing a huge tear in the armour. The edge is carbon tipped, so Titanium is not even there as far as Im concerned.
Power: a pair of LEM 130s on 36v running through a Storm 2 transmission (with 6 vulcalon wheels, with small screws in them for that little extra)
Armour: 4mm Hardox and 2mm stainless steel
Srimech: invertible
Speed: 27mph
Strengths: vicious weapon
Weakness: Unique weapon, may be mis-understood
Weight:100kg
Dimensions: 100 x 100 x 35 cm
Shape: Low wedge, rounded back
Weapons: A 750 PSI pneumatic arm that is mainly for self righting but can be used as a weapon, and a set of 3 Kill Saws at the back. The Kill Saws four, 20 inch, carbide tipped, SystiMatic saw blades. The blades are powered by a 48 volt, 3.5 horse power motor and can shred titanium and many other things too.
GC: 0mm at the front, 1mm the rest of the way
Wheels: go-karts
Power: a pair of Bosch 750s on 36v, whereas the weapon is on 48v
Speed: 18mph
Armour: 2mm stainless steel and 4mm aluminium
Strengths: rip-roaring weapon
Weakness: iffy armour
Weight: 100kg
Dimensions: 100 x 100 x 50cm
Shape: Vortex, but without the motor sticking out the back
Weapons: A 27kg outer-rim weighted steel vertical flywheel, Powered by a B&S motor at 48v and run through a 40:1 ratio chain and sprocket transmission. The disc runs at 3500RPM but packs a 79Kj wallop (I worked it out; it€™s not that dissimilar from Matildas tail disc).
GC: 3mm all the way around
Wheels: 2 x Vulcanised Aluminium hubs
Power: a pair of Bosch 750 watts motors running on 36v (Like Flaming hell, wired so the drive gets less and the weapon gets more) running through a 10:1 ratio gearbox
Speed: 12MPH
Armour: 6mm Stainless Steel
Colour: Black, with pentagrams and demon faces painted in random places
Strengths: Devastating Weapon
Weakness: No srimech as such, but can run on the disc, which is then thrown into reverse which causes the robot to flip over, Stinger Style. Tipped right way up
Hell Fire
Weight: 100kg
Dimensions: 120x110x40cm
Shape: low slung wedge
Weapons: Powerful 1000psi pneumatic flipping arm that has a plate that runs the width of the front, that can throw 175kg 3 feet or so no problem, and can, flip 300kg, but not too high, and a rear Pussycat style Saw, that spins at 4000rpm, and has carbon tipped teeth to cope with titanium.
Top Speed: 25mph
Transmission: a pair of Mag C40€™s on 24v NiMH€™s running through a really simple transmission, but a reliable one due to features to keep the chain on.
Amour: 6mm Ali and steel alloy and 3 mm of stainless steel on top
Strengths: Very manoeuvrable and fast, generally very easy to control
Weakness: Exposed outer wheels
Ground Clearance: 0 at the front, 5cm at the back, varying from 0 to 4.5 at the sides (wedge goes up)
Turning Circle: 0cm (its turning is very nimble)
Notes: Hell Fire is extremely manoeuvrable because it has 2 sets of wheels on the same axle, meaning that it€™s incredibly stable, and can turn on a penny, and can still run even with outer wheels ripped off
Apologies for the bump, but okay Alex. 5 people.
..Come on! Just 3 more! Please god, please god, please god...:P
Ill enter, get back into the swing of things.
Can I give you stats later? I havent done this in ages:P
Awww, I just read it properly, its a tribute to me and Dave. Thats the biggest compliment Ive had in zonks :proud: *Refrains from hugging Tony*:proud:
Alright, message for all:
Whoever it is who has impersonated Steve, saying PTT5 was cancelled, WILL be banned from this tourtament, NO QUESTIONS ASKED, NO EXPECTIONS. IT DOES NOT MATTER IF YOU ARE ALREADY IN OR NOT. SAME GOES FOR MINI-MIREC TOO.
