Spinner motors
Most ants that use 12v (12.6v if you want to be accurate, 3 x Lithium polymer cells) are spinners, and as such have a ESC for the weapon motor, this normally has a voltage regulator onboard, which you then use to power your reciever and drive servos. If you want to run more than about 6v in an ant without an ESC, then you simply take 2 lines off the battery, one of which goes directly to whatever it is youre running at the higher voltage, the other of which goes through a 5/6v regulator to the RX and other servos.
Spinner motors
Spinner motors
Some servos can supposeldy take it, usually the larger ones. The micro servos get upset above 6V really. Some have had success at 7.2V. It all seems a bit hit and miss really, but yes, the rest of the ant is run off the BEC
Spinner motors
Eddy that sounds like a good idea. I have a static prop balancer which has been good enough up to now (max 35000 rpm) but if I do get vibration problems I might just look into that.
Spinner motors
yay my stinger arrived today :)
nice pic of it sitting on the new ant (wheels are just there to give and impression)
http://s4.invisionfree.com/Antweight_Forum/index.php?showtopic=66&st=0&http://s4.invisionfree.com/Antweight...topic=66&st=0&
Spinner motors
Having said that, model gas turbines are usually statically balanced, and they run up to about 160,000rpm, so it works, with a little bit of patience. Just a thought :)
Spinner motors
what do most people use to connect there spinner weapons to there motors? I was thinking of just placing the(thin undercutter)blade directly on the motor.Mainly to save space& up the rpms :)
Spinner motors
Most antweight spinners have the disk/blade mounted directly onto the motor output shaft, the only exceptions I can think of are Pixiedust, a FBS that uses a small gearbox to up the torque, Duff (I think) who again has a small gearbox, and Zenith (mine) who uses a 3:1 belt reduction using pulleys and belts from old cd-rom drives.
Spinner motors
and DBA(a.k.a. KillSaw) which uses a 1:3 gear reduction
Spinner motors
*slaps forehead* How could I forget DBA :) My apologies, Tim.
