I assume you are using a 3S battery with the Argos drills? Most Linacs are 12v, so you should be fine to run them on the same battery providing you have a big enough mAh battery capacity.
Edit: You are clearly using the drill battery. I assume you are planning on moving over to LiPos, from conversations we have had in the past?
