I happen to know that The Westminster Warrior uses the same motors as The Honey Badger 2.x and would recommend using the same motors again but use a pair of Gimson hubs that fit those motors perfectly and are pretty durable. The minus point is that you need to align the hub onto the wheel with care but once on, it isn't coming off. ;)
Thanks for the advice, the current ones somehow still work but I'll make the next incarnation four wheel drive. With any luck it will last more than two fights next time!
