Hmm, I don't think I ever turned on Elevon mixing, but I think I have your solution. I believe it's because it's designed for mixing the elevons on an aircraft, so it tones the power down a bit.
https://youtu.be/6Ewa79_9Iq4
You have to turn the trim adjust up from 100% to 125%, works fine now :) Thanks!
No problem, always happy to help!
http://i2.kym-cdn.com/photos/images/...34/142/196.jpg
Nothing.
Go to the endpoint settings and put aileron and elevator both on +125% and -125%
Hi all wondering if anyone can help me out, I've set mix 1 and 2 and it works but I've some how managed to get forward and reverse set up on the left and right of the stick and to turn left or right I have to move the stick up and down. I'm probably being a complete numpty but if anyone could help me out I would be very greatful.
switch out your esc's
Thanks, been a long day why I didn't try that I don't know.
Switched out the ESC's only thing it did was make it go forward pushing the stick left instead of right :(anymore help? Currently have it going forwards and backwards on moving stick left and right and turning on moving stick up and down.
mix 1 is aile - aile
mix 2 is elev - elve
trim active on both.
Pretty sure you need to do aile - elev and elev - aile, since you're basically mixing the action of one channel into another. Then work out your % values as needed to make the motors go the right way.
It's done! Kept my mix 1 and 2 the same and followed the instructions in the picture and it's worked a treat :) just need to work out now how to dile it down a bit as it's rapid lol
http://www.fightingrobots.co.uk/webk...a2e7b/imagepng
