Yes, the ban does include any commercialy available blade that can shatter under impact. Even the shatterable parts are only the teeth.
I myself favor the "monoblock" idea.
A disk/drum/eggbeater fabricated from 1 piece of metal that resists shattering whatsoever.
Hardox or Cruesabro comes to mind.
The rule, or rules in this case, are specifically -
12.3 Rotating Weapons
The speed of any rotating weapons - e.g. circular saws, carbon or steel cutting discs - must not exceed the
manufacturer's specification. The manufacturer's specification must be available for inspection.
12.4 Hardened Blades
Commercially manufactured, hardened steel blades that may shatter are not allowed.
So far as I know there would only be 2 types of commercial blade permitted -
Friction Saw Blades - http://sheffsaws.com/circular-saws/friction-saw/ - The same type that Dead metal used. All 1 piece with a hardened edge. Expensive!
Diamond Abrasive - http://www.screwfix.com/p/erbauer-se...0-x-20mm/32833 - These are 1 piece of metal with an abrasive powder glued to the surface. Rather than shattering the abrasive section would turn almost to dust.
However, since I am pretty sure you would bust a commercial blade every fight I would recommend getting a disc custom cut from Hardox or another type of wear steel. This would only only be more effective but cheaper. I can work with you to design one to fit your needs and there are many other people out there with access to CAD as well.
I dunno, you'd have to double check with the event organisers and ruleset. If you put anything on a robot that spins quick you immediately limit yourself to the one event a year that can cope with featherweight spinners. If you wanna go to a few build a non-spinning weapon.
That would be great if you could be appreciated. Think a custom made blade from Hardox would be best
Ah, yes. I will clarify. Spinners are not permitted at all events. Only those with Class 1 Arena's.
Since the only Class 1 arena's in the UK are the new Robot Wars arena in Glasgow (which we can't use) and the Robochallenge FW arena, which is only used twice a year at most, your robot would be limited to just 2 events a year: The World Champs at Gadget Show Live (which just happened) and possibly an event at Fleet Air Museum (which doesn't always happen).
The rules above 12.3 & 12.4, would still apply at the Class 1 arena events.
If you don't know what I am talking about, read the Rules and Safety Documents - http://www.fightingrobots.co.uk/cont...s-and-safety_1 - You may never run an event or need to know about stopping EM interference but its good stuff to know regardless.
Is this for vertical spinners aswel as horizontal ones. I mean could I enter more events with vertical spinner? (Thinking of a slight plan change)
nah, they have the same rules as horizontals
1 Attachment(s)
It doesn't matter what angle the weapon is at... 45drgs, 90drgs, 3.1415926drgs...
Attachment 5828
if its over 500RPM it counts as a spinner, and even then the EO has final say so I wouldn't even bother taking one to a live event.
Stumbling upon this thread, and it sparked my curiosity.
What are the rules in regards to making a robot that looks like a full-body spinner (blades of some description fixed to the outer shell), but it simply rotated on the spot using it's drivetrain (like TV Series 2 Spin Doctor)?
The chances a normal drivetrain FBS runs over 500 rpm are slim. Also, it's difficult to forbid robots to spin on the spot.
