Working Perm has been sold!
How much for wheels and charger mate
Mark, charger is long sold I'm afraid. Which wheels are you interested in?
Smaller ones and no problem about the charger
PM sent
Found something else during my adventures finding stuff in storage.
A bit of pipe!
But this is no ordinary bit of pipe, no no. It's a bit of pipe with a cut through the middle!
So the story behind this is that it was a test piece used on an explosives course that I attended a year or two ago. It was used with a flexible shape charge that blasted the cut through the middle (roughly 180 degrees around). They were going to throw it out after we were done but I asked to keep it with the intention of using it to build a heavyweight drum spinner one day. Well that's probably not going to happen so I thought I'd offer it up here and see if anyone is interested with the re-emergence of a certain TV series. You could either continue the cut and have two sections or even fill in the gap with weld material.
Stats -
- total weight - 15.4kg
- diameter - 230mm approx
- length - 300mm approx
- wall thickness - 9.25mm approx
Pics below. Make me an offer if you are interested.
