Yeah you'll be fine just have a bash :-) the zippy will be fine, if it's a 1000mah batt then it's a 1amp hour, and 25c means it will give bursts of 25xcapacity so that's 25amps max. So you're within range of xt30 capacity.
Does anyone know if the gearbox off the 1000rpm 12v motor off eBay are comparable with any brushless motors?
Yeah a few people have used them, not sure which size motor fits but it was a direct replacement. You swap the pinion onto the brushless and it screws together. I can find the threads if needed.
That would be awesome, I will also have a look myself to see if I can find it.
