The axe for DUMBLE turned out awful, gear ratios all wrong and motor not powerful enough. :((( Time to slow down a bit and do a proper job Instead of rushing into things.
Time to get cutting for ACE
http://www.fightingrobots.co.uk/atta...tid=5681&stc=1
There is this one test you ought to do before throwing your machine in the arena.
Hoist it up about 7 ft and let it drop...
Still working? Great! You build a machine that can sustain a heavy crash.
Not working anymore? Great! Now you can check what area's need improvements.
Is £198 per motor expensive for a direct replacement for the Bosch 750 GPA ? same mounts and spec.
as in a custom motor ?
No I have found a company that sells the direct replacement, I just don't know how much the old 750 gpas used to cost brand new
£120 ish + vat from memory I believe there is a whole thread on here about ellis components selling them !
Any chance of a link ?
£200 is a tad steep. For that amount it's almost an option to look at the F or E series from Ampflow.
How do the E30-150 compare to the old bosch 750?
http://www.active-robots.com/ampflow...-motor-e30-150
Bosch 750 any day even the 400's did not match the 750
