We could just about build Tormenta 2 from scratch with a £600 budget. It has 4 wheel drive, an active fast-moving electric lifter/flipper, and a thick plastic chassis. However it was our second machine, so the money was spent more efficiently than if we had attempted the design for our first robot.
A budget of £500 will get you by nicely. If you have access to basic tools and some scrap you could potentially halve that.
You might want to consider putting a little less into your first machine, as even if it doesn't get badly damaged, you'll probably want to rebuild fairly soon anyway. It's just how we all seem to work. That doesn't mean it can't be solid, if you know someone who can weld, mild steel is cheap, or free if it's otherwise scrap, and if thick enough you can make something that will comfortably take the hits.
I'd try to get to the UK champs, because you will learn at an immense rate. The rumbles at HW events are fun, and they will be a good electronic shakedown, but they won't tell you a lot about any major design/mechanical issues. And the chances of a spinner destroying your machine to the point where nothing is salvageable is... well it doesn't happen anymore. The whole front end of our first machine got obliterated by the later crowned '12 champ, but the only broken electrical component directly caused by the attack was the loss of a few AAA batteries. Unlike in RW days, where continuing to smash a dead robot was the norm for good TV, that doesn't happen now; the driver of the robot doing the damage will stop attacking once your machine stops, and that's that.
