Your charger can charge LiFepo4 batteries up to 6 cells.
The Turnigy Accucell will indeed charge A123's, you use the LiFe setting on the charger Sam.
http://www.youtube.com/watch?v=eX_Tuv6WOf8
And yes modifying packs isn't difficult, ours are all soldered as Gary says and can be stripped down, reconfigured etc. I would suggest if you want to start playing with packs that you take a look at this.
http://terrorhurtz.com/a123/build.aspx
Clearly you don't need to do quite as much work when you're modifying the packs yourself but it will give you an idea as to what you're doing !
BTW, suddenly loads of interest in the packs, only a couple left.
I should add, that anyone wanting to change the configuration of the packs, I have plenty of heat-shrink that will fit the packs if laid out as .....
OOOO
OOOO
if you wanted to make 8 cell packs for example, so long as you have to cells side by side I can throw in some heat-shrink :)
How many have you got left ed ?
Terry, between 4 and 6 depending on what people who have expressed an interest in actually buy. I also have around 14 cells packaged and un-used, more than enough to make up some more packs if need.
Drop me a mail if interested Terry
