Voltage regulator
Voltage regulator
Its easy, take your 12v strip and cut it in 2 bits both same lenth, then wire both together in series. Worked for me in toxic for a few years. My 2 x 12v strips run on 30v quite happily.
That's a brilliant idea! I've already got it in 2 strips in parallel so dead easy to change it to series. I also think I've solved my shorting problem so may have time for a test run tomorrow, it should be much faster now with 24v, 150mm wheels as ive fixed the half throws from the mixing.
