I'll try that and get back to you :) Thanks
Just wanted to check this before I did it (I'm a noob and I've been scarred by 4QDs exploding randomly in my face before). The charger attaches to the battery by an Anderson connector, should I disconnect the Anderson, join one side with a wire, then the other side with the multimeter? Just thought I'd best be sure before I ruin everything...
Yep, if I can understand what you meant, the ampmeter will go in line with the positive or negative wire, you could just pop one of the metal clips our of 1 Anderson so there is 2ends left, then put the 2 ampmeter wires to them.
Like this: Battery on the left, charger anderson on right.
(forgot to attach the pic :roll: )
