10.9v
10.9v
receiver, not transmitter
reciever is pluged into the robot esc which workes fine and the supply battery is 14.8v
the 40mhz reciever was pluged into it and working the esc today.
are you sure you have soldered it to the correct pins and that the joints aren't dry?
quite sure, also sure ive got the antenna the right way but there was no pic in the instructions to show what way round to solder them in, was a bit of a fiddly job on them !
but the rx does flash to say its recognised the tx though.
I used the frysky hack on a 6EXA no problems (until i melted the battery in it).
