Re: Best wheels ?
link? doubt it, its the current handling thats the issue, you will probably find they can only deliver 30-40amps. Even bigger SLAs like the 18ah (the size most used) will only deliver about 100amps. The only exception are Hawkers which will chuck out 500+amps, but your looking £100each.
Re: Best wheels ?
Re: Best wheels ?
The spade connector ain't a good sign. It says 100 amps, if you're lucky.
On the other hand, Gravity and TAN did, and do good on that type of battery (other brand tough).
Re: Best wheels ?
But is has Ultra Max written on the side! They've got to be good right?
I liked the idea of using hobby LiFePo packs in a HW, cheap, light and powerful.
Re: Best wheels ?
looking for a 2kg co2 bottle or there abouts, design changed to possible co2 axe or lifter bought the high flow reg thanks to ebay and WRANGLER, just waiting very happy should be great, any ideas ideally aluminium to save kgs
thanks adam
Re: Best wheels ?
2 x 1000w scooter motors
2x10 teeth 2x11 teeth sprockets
4x74 teeth sprockets
all orderd just deciding on wheels, and weapon
Re: Best wheels ?
4 large 260mm faom filled wheels ordered
will this co2 be ok not sure on size if to big,
http://www.ebay.co.uk/itm/221177181354? ... 1423.l2649
