your bot looks exactly the same as mine :)
Haha, that's just an explanatory diagram but I imagine many bots look roughly like that xDQuote:
Originally Posted by archie2000
Only thing i would say about table saws and hdpe is that it has a tendancy to wander. It's either a two person job to keep it straight or i find it runs better with a couple of pieces of wood under it (just 10mm runners)Quote:
Originally Posted by maddox10
I use a jigsaw with a metal cutting blade and a router for all the groves and angles, works well
I use a circular saw with standard wood cutting disc
I clamp a straight edge (bit of 2 x 2 wood) on the HDPE and run the edge of the saw against that. Gets a nice straight cut
It does create alot of swarf (not sure thats the right term for HDPE but you get the drift) so watch for that.
I also have a chop saw for wood that comes in handy for short cuts
I find hole saws and HSS drill bits work fine as well
For the antweights the pieces are small enough to clear the cuts on a bench grinder (with a light pressure to avoid too much melting)
i thaught i had loads of tools at home
