Re: Someone local for roboteq help
Just checked the rc gear, thats all fine but it shows us with ' NO CTRL' which it did after guildford. I took all the leads off, cleaned up the original plug and put it back in, still does it but the issue is im not sure what pins the wiring loops go onto on my ax2550 as my current set up, connect the positives and it turns off altogeather but I still get no response from the valves. When it did work, left was forward.
Its probably a very simple solution as it was working before, yet it just wont now
Matt,
Just get a new lead from technobots. They're a fiver at the moment so you could only just make them for that money.
Even if it doesn't work you at least have a spare.
These leads break regularly so you need them anyway.
Once you've done that then the rest of the stuff is easy to check.
Andy
Have done already, for the sake of a £5 its worth a shot and got a spare if its needed
Popped a few pics up in my build diary
