back to the :roll: drawing board
3HOURS
3HOURS
aluminium is 44grams a cm3
what do people do for a material.
polycarbonate is light and strong but too shattery.
ti, hardox or i use p20 tool steel
all quite heavy
ti is OK
well you want it quite heavy.
Aluminium is not 44 grams cm3 it's a 10th of that, about 4 grams cm3
really?
that's nothing
time to make bot bigger
alu is too soft for discs tbh
like 1cm thick is enough.
anyone ever had bad experience with aluminum in discs
at 10mm thick you *should* be okay. 2mm ti would be better tho
