hmmm i see your point from my measurements its around a 20g difference
and when your building somethin in grams a difference of 20g is quite big as roboteers i think we all understand :talker:
The question stays the same.
What is that weight worth?
enough to make extra hassle and work worth it
If weight is so important and strength isn't couldn't you go for a steel m3 or even m2 rod as may still be stronger but similar weight to Ali rod?
Well doing a quick search, ebay threw up some M6 ali threaded rod and if weight is a real issue but strength isn't as bad then you could go for plastic
http://www.bluemay.co.uk/plastic_fasten ... d_rod.html
cheers for that Gary, checked it out but would be £50 :shock:
