Oh great the wheels on the front don't turn I will have to buy a different type of wheel I need this doun by tomorrow
The robot looks very neat pugster!
I have found getting straight lines with thin polycarb 1-1,5mm can be quite easily done if you use a ruler to draw the edge and then cut or have someone help you cut it 2-3 times in that straight line with the help of the ruler to keep the knife going straight.
If you then bend the polycarb with this cut line at the egde of a table or similar the polycarb will crack just along the straight line and you get a really straight edge, it might be worth a try on your next robot or something like that :)
just use scissors for 1-1.5mm
I have finished it look http://i1101.photobucket.com/albums/...9/b0541911.jpg
You made that really quickly!!! :o how did you bend the plastic or the flipper?
How did I bend it I just melted the plastic then it was super easy to bend :D
that's a brilliant robot for your first! :)
That looks really cool!!
Here is a vid of it http://www.youtube.com/watch?v=vFZrcuWJ ... ata_player
a lot better than your last antweight, well done :)
