kinda just got one matt, normal fw parts plus bar and motor (with some belts and timing pullys etc)
And ESC for the bar ;) lol
there you go, you've done it yourself :lol:
If you go for a car fan motor (or even Speed 900s) I'd just go for a battle switch/relay combo. Spinner ESCs aren't really necessary (brushless stuff aside) as most of the time you'll be running at full speed anyway. Just easier to flick a switch and enjoy the buzz of it spin up :)
Don't be surprised if the cost of things such as pulleys, belts and various washers and/or fixings needed for a spinner is more than you might have expected. With my first spinner I spent a fair few quid on things I thought I'd need but didn't, or didn't use because they weren't quite right for the design. A good degree of planning can help but trial and error plays a big part.
So current list is:
Box frame chassis
Polycarb armour
2 drill motors
Set of wheels
15a ESC with 30a fuses to run 18v
18v Nimh pack
Fan motor
Stainless steel bar
Relay/ESC, what ever I can get
2 pulleys for 1:1 ratio? Not sure yet
Belt
Various bolts etc
All sounding good?
Sounds fine. You will also need a shaft and bearings for the bar. I'd recommend a shaft of at least 17mm diameter silver steel or similar.
http://www.technobotsonline.com/pulleys ... x10mm.html
These would do for timing belts/pulleys for the bar. Make sure you get a spare belt or two.
You can go for the box section construction if you want but few feathers go that way. Instead the monocoque is prefered. You've got a number of options but the easiest to make is a plastic based one. Nylon for structural bits and pieces.
Cheers Gary, forgot about that
I've got enough for armour, spare esc's, metal for chassis
So I need some motors, wheels, batteries and the disk set up. Should come under £120 if I shop right. This will probably be a one event spinner just too see how it goes
even at the worst, it should cost £140 to build the spinner
if i can sell enough of my crap that i dont need then it should be achievable
What escs are you using?
woops that was supposed to be a pm
At least I can use the quote thing now
