have you watched the vid as it tells you how to do it very clearly
Woops, didn't notice your post above mine, we posted at the same time effectively and I never checked, thanks. :)
So after a long break, I'm fully on my way to getting this bot finished
http://imgur.com/a/5xaf7
I've added a bar to the back and some aluminium cones to the sides to allow the bot to roll, and the wiring is coming along well, built the batteries a box to sit in and to allow room for cooling, and the RC module is sitting on a stage type thing to allow cool air to run over and under it. Just gotta sort out the final bits of wiring and a cover for the switch hole on the side, then it should be set to go!
Last time I checked the total came to 11.2kg but I've added on a few bits since then so I imagine it'll be around 12.5-13kg now, don't have digital scales to use unfortunately.
