Normally push fittings are rated at 8 to 10 bar, I had one blow apart at 11bar. There are all metal ones good for 15bar, but they are expensive, the way round that is using small 1/8 fittings on all the system apart from the buffer and the ram, the smaller fittings cost less..... btw. it will be difficult to do away with push fittings, even if everything is fixed, as long as you're not using metal tubing and compression fittings!
Alex, there's no way you'll be able to penetrate titanium alloy, neither at 1.5mm and much less at 3mm, at most maybe you'll dent it, that's all. But you're free to prove us all wrong! ;)
