That might just be the best looking vertical spinner i've ever seen, it's so neat and strong looking
looks great, will drive nice to I imagine as the discs not overpowered, will be a strong contender... any plans for a self righting? you've got the weight for something similar to deamon in AUS...
The logic behind a scoop is that although it lowers the number of impacts, the impacts it gets should be better because the scoop feeds other robots into the disc better than just a flat front to the robot. That's my theory anyway, will be interesting to see how well it performs but based off other machines it should work quite well.
The gyro effect will be another thing interesting to find out. The spinner isn't overpowered as you say and the wheels aren't too far from the disc axle so that should all help, but at the same time the drive is seriously quick so that will add to it. I think it will just be the case of getting used to driving it to counteract the effect as much as possible.
Will have to look into self righting, another thing just too see what happens really and I'll go from there. When it is turned upside down when the disc's still going it's not just going to sit there, but I doubt it'll be enough to turn it back over unless it lands lucky. Having said that the front end is pretty good - should be on a par with Explosion and that gets under most other robots, so it might depend on how easily it gets flipped in practice. So long story short I'm going to see what happens this year and go from there - won't have much more time once the events start anyway!
Wow, that looks awesome. Looking forward to see the weapon doing some damage aswell.
First spin up
http://www.youtube.com/watch?v=5VN0B...ature=youtu.be
Looks very nice unfortunately ;)
That's genuinely scary when you watch it with sound! Am now glad I haven't entered the champs with one of my plywood creations!!
Has to be one of the best sounding spinups ever.
Tiny Toon says to say hello :-)
