So this evening I reflashed the TZ85A and we are back in business, both drive ESCs are working. I also reconnected the FeatherTwo to the weapon motor and after checking that the polarity is right this time, verified that it works. The next thing is to get the two co-operating with each other on the RX. I'll get a JR servo extender cable and put the power lines in there rather than cut the FeatherTwo's wire in case I need to have it powering the RX again.
However, things now look promising to have it done this week, get through Manchester 2018 event with a potential test match beforehand and then get the thing properly rewired for the upcoming FW championships.
UPDATE: I connected up the FeatherTwo to the RX via the JR servo extender with both of the power wires cut, leaving only the signal wire connected and whilst it does turn on (the orange LED blinks), nothing happens when the switch is thrown on the TX. Will look into this tomorrow.
