James,
Did the entry form have a space for the names of team members or how many we are bringing along?
James,
Yes it did Dan, do you need to make changes?
When would you be doing the draw james ??????
Shane (team tilly)
within the next 2 weeks.
James did I have the girlfriend down as an additional member of my eh team?
With 3 robots trying to get in? Just increase the size of the champs by 3 spaces!Quote:
Originally Posted by james...venom
Actually, if you do the math, it works better than 45 robots, 48 can be split in half for 2 equal groups then divided into 8 equal 3-way heats each day, without any 2-way only fights.
Anyway...
Name - Skyfall
Weapon - Full Pressure Flipper
Armour - HDPE, Ali
Drive - 2x Speed 900s
Other - Not finished yet :P
Name - Ricochet
Further Information Withheld on the grounds that I want it to be a surprise and I don't know myself to be honest
Weight: 13.55kg
Drive: 2 x 12v RS550 24:1 at 4S LiFePo
Weapon: 70mm Alu drum with 2 teeth (made from spring steel), spinning at REAL 12570rpm
Armour and Chassis: all sides with 20mm of 7075 alu, top and botton 5mm 5083 alu
Notes: Second place in 2013, because first is to Boner :)
http://sphotos-g.ak.fbcdn.net/hphoto...65977831_n.jpg
Weight: 13.6kg
Drive: 4 x 12v RS550 24:1 at 4S LiFePo
Weapon: Claw powered by a Turnigy 4260-600Kv outrunner with a ratio of 150:1
Armour and Chassis: all sides with15mm of 7075 alu, top and botton 5mm 5083 alu
Notes: Third place in 2013. Please, don't lose to my GF!
http://www.youtube.com/watch?v=xEKnUgeAwCc
See you in arena!!
Guilherme Ferreira
Don't encourage him!Quote:
Originally Posted by RobotExtreme
To do a full build good and proper for my new spinner will take time...I wont have time to get into this years champs so can my name be removed from the reserved list please..... However....
I can say I will be at the champs with the weapon I will use for my new robot but added to another current featherweight robot. So I will be part of a new team. I will confirm with my partner this weekend and let you know James. For now.... the robot my weapon will be mounted to is already on the list so no worries. :)
