FRA Royal Robot Rumble: 30 enter, 1 leaves
Weight: 100kg
Dimensions (LxWxH):120x80x30
Shape: Full body invertable spinner.
Weapons: It IS a weapon all over. 28 KJ power
Armour: 4mm Titanium
Top Speed: 20MPH
Main Tactics: Circle until spinner is going full speed then attack. Careful to avoid hazards though.
Colour: Red with black writing
Strengths: High powered weapon.
Weaknesses: The ping effect and when its upside down the controls change (up becomes down) so that has to be kept track of. Also, being invertable, its wheels are vulnerable to axes.
Name: Natural Selection
Paint scheme: Green
Wheels: Four, inside
Shape: Boxlike. Scoop on the front, skirts around the sides, the back is rounded to help with self righting.
Dimensions (cm): 80/40/20 (L/W/H)
Weight: 100
Armour: 4mm ti
Weapon: A hydraulic lifting arm with vertical pincers. These are made of titanium and powered by a linear actuator, giving 400 KGs of grip. The arm is 70 CMs long.
Motors: Two Bosch motors.
Batteries: Natural Selection is powered with Hawker Genises batteries, which are placed in the rear to act as a counter-weight
Top speed: 15 mph
Turning circle: Zero
Ground clearance: 10mm (There will never be a completely flat arena floor, 0 would be unrealistic imo)
SRIMECH: The arm.
Strengths: Crushing power
Weaknesses: Slow to self right.
Robot Name: Love Bite V 2.0
Length/Width/Height: 120/30/20
Weight: 100KG
Motivation: 4 inner wheels
Speed: 30MPH
Weapon: €œWeapon type and specs€ Hydraulic pincers at 2000 psi, can damage light-moderate armour. At the front is a Firestorm type flipping arm, CO2 powered, really just a SRIMECH but it will get other bots over, not really meant to be an OOTA flipper seeing as it€™s speed and the pincers do most of the damage.
Drive: €œMotors used and voltage, style of reduction€ Bosch motors at 36 volts, gear reduction
Power: €œBattery type and Voltage & Amps€ 2 x 36 volts at 3 amp NiCD packs
Armour: €œMaterials and thickness, method held on€ 4 mm hardox, welded.
Ground Clearance: 3MM
Turning Circle: 0M
Notes: It is a double wedge with skirts around the two sides. The paint job is black with Love the Bite in red down the skirts.
After rereading the rules (no shufflers? DAMN!), Ive decided to replace Whirligig with Toby. Stats in the same place. Also, increased battery power and CO2 permitted by da rools.
Curse your fussiness, Davey :proud:
rumble
disco 5 boosted
and someone else
royal
disc-o-inferno
panicking
stats when there found/made/finished
Sorry, but thats the way its gotta be to avoid confusion.
BTW, Extra CO2and batteries have to be declared, or you may fail mid battle.
UNDERSTAND ?!
ok, Love Bite V2.0 will have 10 KG worth of extra CO2 and extra batteries, the others will have as many extra batteries as i can fit in 20 KG
Come on, I resurrected this thread for me to write a big-ass fight. I need more robots !
for the rumble both machines have around twice the weigght in batteries, in both machiesn this weight is achieved by takign weight off the wheels which make up a large proportion of thwe weight
Tengu gaisn an extra 5 kilos by dropping 2.5 kilos from each 7.5 kilo blade
kali should have ample co2 to last the fight, because the gas is stored at high pressure but released much lower it means i should get in excess of 150 flips before havign to refill
Ok Alex, Ill bear that in mind
Me and my entries
Pie of Doom HWBE - stats later
Anti-Spin
Royal
Quocunque Jeceris Stabit
Ewe 2
Anti-Spin and QJS can be found here -
http://farr.proboards21.com/index.cgi?board=TeamSolarizedStatshttp://farr.proboards21.com/index.cg...SolarizedStats
Replacing Pie, cos its a LW and looks like a pie, here is Brucie :proud:
Robots name - Brucie Bonus
Mass - 120 kg
Weapons - Long-lasting low pressure nitrogen flipper
Can it self-right - Using flipper and it can run upside down all day
Velocity - 10 mph
Turning Circle - Skid Steer
Ground clearance - Front is 1mm, rear is a massive 2 cm
Skirts - Nah
Wheel Type - Solid, 4 on same axle.
Motors - A common of Bosch 750s at 36 volts
Body Shape - Wedge front, box rear
Armour - Titanium,
Colour - Grey
Batteries - Enough to last ~ 30 minutes
Summary - Old school
Strengths - Designed to last for long fights
Weaknesses - Bit Boring
