New FW database (new robots)
update on 360 -
Found a voltage drop problem due to the disc motors sucking so much power from the main battery pack, so will need an exstra small pack to power the drive.
Spinup time with two motors is improved and power seems good- took a damage comparrison picture against a peice of 3mm steel hit by scorpion and hit by 360 (scorpion damage on left- 360 damage on right) will be on profile soon.
Also- does anyone know were people used to get the brass gears for bosch 35s? i damaged one of the standard nylon ones.
http://uk.youtube.com/watch?v=alE3UNMcDXchttp://uk.youtube.com/watch?v=alE3UNMcDXc
Just a quick vid on youtube showing 360s testing on 1 motor.
looking sweet guys, look forward to seeing it in action.
Small update with some pictures. I had 2 steel plates cut to try to make a setup, so i can test drive.
http://picasaweb.google.com/Jeroenvdlo/Firestarter1http://picasaweb.google.com/Jeroenvdlo/Firestarter1
New feather spinner designed and being built by my little cousin.
Drive: bosch 35s
power: lipo
Weapon: vertical spinner run by brushless and lipos
details: IG-88 type bot
Baramot 2
Ram bot.
Drive 2 x EV Warriors at 24v.
Armour Front 5 mm Ti plus 4mm Hardox
Sides 10mm polypro plus 4mm Ti
Rear 4mm polypro plus 4mm Ti
Controler Sidewinder
Nice. Ill have to get Relentless done and we can have a little rambot battle, btw i know yours is better. Oh yeah get on MSN Tony.:mrgreen:
Update on mayhem
Started again for about the 4th time now
Axe 20:1 speed 900 on 12v controlled my victor 883
Drive 5:1 speed 900 on 12v controlled by victor 883s
Shape same shape as tuffluck 1 but abit bigger
2mm steel armour for now will be 4mm before it fights any spinners base 4mm aluminium tops 10mm poly
So far Ive built the axe gear box mounted the drive and got it going and cut out the base and started Saturday hope for it to be done for Barnsley but will see
New 5mm Ti armour done for Dragonstrike just got to fit it. Pic on profile
Me thinks he is prepareing for something :)
