was it the action bot that will has now that had the 4 bar in?
if i was to go with this do you still know what the specs of the 4 bar was?
Tom, might I make a suggestion?
Put all of your questions down on a piece of paper and put one or two posts on the forum each day. It becomes difficult to follow what you are asking and difficult to answer your questions.
yeah ill have to remember to use my brain and think ahead :p i usually just wait for things to pop into my head.
ewan have you found out when the 100mm wheels will be available?
Got nearly everything ordered now i just need stuff from ewan and sum sort of a pneumatic system.
anyone got any old pneumatic stuff or know where theres sum going cheap?
then i just have to think of a chassis/body design and what to build it from.
Im chasing up on the wheels as I speak. Hopefully I should have another lot in stock by the end of next week.
All the best
ok cheers fella. know anyone who might sell second hand or just cheap stuff for a pneumatics system? needing solenoid valves etc
Any news on those wheels yet ewan? ohh btw what were micro maul evos dimensions? Length/Width? im going to make a chassis like that out of 20x20 box only for 100mm wheels. im having polycarb base sides and top but im having them set into the chassis so that its flush and ill just put some 25x3 flat tags inside to fasten the polycarb to. then ill just have to see if its strong enough. then i just have the risk of a weight problem.
Theres some pneumatics stuff here http://www.airlines-pneumatics.com/webcat/product-index.asphttp://www.airlines-pneumatics.com/w...duct-index.asp whole systems seem hard to come by.
Theyre being made up as I speak so I am made to believe! Again sorry for the delay.
Cant remember the exact dimensions as I sold the thing off a while ago, but I can tell you it wasnt wide enough! Was too tight a fit to get the drill motors in comfortably. I think it was approx 340mm wide (inc box sections and outer armour) and then around 450mm long (again, only 50mm body height :))
no problem im not 100% ready to get building yet still trying to work out what size i want to be. ohh ill need a 100mm empty gap or somthing in the middle maybe more. i think ill have to go wider than long which i didnt really want to do cos i think i might have to go about 480 maybe 500 wide but if i ant to go longer it will enf up being over 500 long it will make the bot really big for a feather wont it? it might just look like a big box when its done.
