Aaron, if the next version of MOABIE isnt called MOABIE Brick, I will hurt you for wasting a good pun:)
franks on 2000 posts anthoer mill stone is passed
How about MOABIE DICK? Mother Of All Bricks Inevitably Evolved Design Into Cold Killer
:proud: 3:10am and I cant sleep :proud:
Even better.
The first Elite roboteer then Franky.
Have a celebration cup of coffee and some cake.
I know, its quite unbelievable how much I rule:proud:
Yes... rule
BIACS-LE
Weight- 100.3kg (WDOR)
Dimensions- H- 65cm, L- 65cm, W- 75cm
Speed- 11mph, 5.1 m/s
Shape- Somewhere between S6 Sabretooth and Atilla the Drum.
Locomotion- 2x Motorbike wheels with screws embedded. These are bigger diameter than the robot itself.
Ground Clearance- Massive
Turning Circle- 0
Armour- A cage made from a 3mm titanium mesh with moulded 8mm fibre glass armour over that.
Power- 2x S28-400€™s at 24V giving 9BHp. These are powered by some TMC batteries at 24V.
Removable link position- Inside the left wheel, as far in as possible whilst keeping it accessible.
Weapon- As before, the weapon is a 300mm 18kg vertical disc on an arm, which can swing right through the whole arc of the robot, and is capable of coming down with a thump. The blades are mounted diagonally, which means that they are capable of both flipping and ripping. The cage can also swing over the top, protecting the axle and wheels from the side that is unprotected by the disc. This means that other than the cage, nothing can be damaged apart from the disc. It should produce about 62Kj. It€™s powered by another S28-400 on 24V and has a spin-up time of 4.7 seconds.
Srimech- Invertible
Strengths- Powerful weaponry. Manouvreable, Strong
Weaknesses- Low traction, slow acceleration.
NAME; Octopush 2
WEIGHT; 150 Kilos
SHAPE; Chassis is like New Cruelty, basic shape is like Octopush from FMC.
SPEED; 18mph
TC;0mm
GC; about 3mm
ARMOUR; 7mm steel.
POWER; Similar to what New Cruelty has.
WEAPONS; A giant Axe device. Instead of an axe head, however, is a vertical spinning drum, spinning at about 1000rpm and coming down, on the hammer arm, at 60mph.
SRIMECH; The robot, if flipped over, can right itself using the arm. The top is curved so it can also roll over. It cannot be side or back stranded.
WHEELS; 8 inner (of course)
INSPIRATION: Tom Brisbourne gave Octopush to me. I made a few modifications.
STRENGTHS: Fairly strong.
WEAKNESSESS: Untested in the field of battle
OTHER NOTES: The drum is powered by its own motor which is attached to the underside of the axe arm (sort of like Sumpthing, only less far to go). 500 holes are also drilled into the robot to keep its weight down.
Windiest Killer
Weight- 100kg
Dimensions- H- 27cm W-75cm L-95cm
Speed- 26mph
Shape- Same as before (See profile pic of Windy-er Killer)
Ground Clearance- 0 all round thanks to hinged skirts rear and sides and the front scoop. 3mm under skirts
Turning Circle- 0
Armour- 6mm Titanium in 4 1.5mm layers hopefully weighing in a around 20kg. The skirts are made of 3mm titanium and are sprung.
Locomotion- 4 wet go-karting tyres with added traction belts.
Power- 4 LEM-170-D127€™s running at 48v providing 32BHp and running at just over 3200rpm powered by APC Back-Up batteries
Failsafe Position- On top of the robot under a 3mm sliding panel of titanium. It€™s about 5cm down, meaning most weapons shouldn€™t be able to hit it.
Paint Scheme- Navy Blue
Weapons- After learning with the previous 2 machines, we have decided to limit the number of interchangeable weapons to one of every type of weaponry which are: Pincers, Crushers, Axe, Vertical Spinners, Horizontal spinners, lifters, spikes and scoops. Some of these weapons are in combination, so these are the weapons.
Weapon 1- A front 5mm Lithium Carbide scoop on which all other weapons are mounted.
Weapon 2- Interchangeable weapon bay
Setup 1- A pair of horizontal Hardox crushing claws with a force of 5 tonnes.
Setup 2- A General Carnage style lifting claw. It crushes with a force of 2.5 tonnes.
Setup 3- A 7kg spinning axe-head with 2 blades on the end. It€™s powered by a 4:3 running Bosch at 3000rpm. Using the Kinetic Energy Generator Program, we€™ve worked out that it gives around 2Kj of energy.
Setup 4- A 10 inch horizontal carbon blade with 4 2-inch blades around the edge, with a 1/2-inch thickness. It weighs 8kg and delivers 10Kj of energy
Setup 5- A small Hardox spike that when at full speed, hit€™s with an 8 tonne force on the tip.
Srimech- Invertible
Strong Against- Non-Pushers, Flippers, Axes
Weak Against- Crushers, Discs on Arms
Robot most compared to- Storm 2 with Tornado€™s weapons
House robot most feared- Matilda
Strengths- Fast, Strong, Versatile
Weaknesses- Anyone stronger
