The option I've used for strip fuses is to glue the head of bolt into the base of the chassis (or otherwise secure it in place) and then you can fix down the fuse and the power lines (with ring terminals) using nuts. I don't actually have a photo but here's a video of me plugging it in.
https://www.youtube.com/watch?v=--c7KetvZzo
All the main power connections are made using ring terminals and M5 bolts.
Good luck with the soldering (and be careful of the carpet)!
