Quick question can 8mm sprockets be easily used on #219 pitch chain, my feeling is it should be ok
#219 Pitch = approx. 8mm (7.774mm)
very close just the chain width is quite a lot wider then 8mm
cant find a 14 or 15 tooth #219 sprocket reasonably priced as they are all custom kart parts and cost more then the 2 new gearboxes put together.
any links or info on this subject would be great.
being used because ceros has been pulled apart again and is waiting on its ampflow e30-400 motors, which will have a simple 2;1 single stage reduction then onto a 6.4:1 go kart drive reduction, keeping it original as possible in size and keeping the gearbox nice and compact. new buffer tank has been made just will need some image native plumbing solutions.
