The chassis is 381 mm long 231 mm wide, going to have to make it wider to accommodate a Burkert valve. Everything you see (apart from the motor mounts and legs which are 6mm 6082 ally) will be 3.3 mm hardox. Yep laser cut MDF, smells lovely! There will be also be 15mm HDPE down the sides and back, 3.3 mm hardox scoop, 6 mm HDPE top. Overall 492 x 355 x 133.
Thanks for the responses :D
