How Could I Improve...
Ben half of those set-ups are identical to one another. Why you need a T-Minus style lifting arm AND a Toro style lifting arm, when they are ESSENTIALLY the same thing, is beyond me. Likewise, why you need two Tazbot type arms, I dont know. You need to think this over.
My vapourbot, Cyclone Force, had 5 interchangable weapons. But since having a rethink, Ive narrowed it down to three.
I can Have 14 It is MY! vapour
I just choose which 5 I want for each tournament
Fine it is a SHW 300KG!!
You didnt answer my question - why do you need 14, and what is special about each of them that there are opponents that only that arm is good against?
Because!
Variety is the spice of life
(Message edited by neontetra23 on July 18, 2008)
Thats NOT a good enough reason, nor is your reason for having 14 of them when you barely need half of those. Stop making such rediculous excuses and try creating a PROPER vapourbot.
Frankly, Im beginning to lose my patience with you.
You can of course do it, but the longer you make your stats the more likely writers are to a) not read it all or b)not take it all in, or equally the fact you have so many setups which havent really thought them out much will subconciously count against you in the eyes of the writer, particularly as the difference between them all seems negligible.
Id not trying to offend you here but bear in mind I have had about seven years more experience than you so I have a good idea of what Im talking about. Especially considering that I designed slammer, which suffered a lot from overzealous interchangeable designs on my part.
ok but i am adding one more:
15) An Axios like lifting arm
Axios doesnt have a lifting arm. Instant fail.
And instead of adding one, try removing 8. Itll work so much better.
Ben, are you now deliberately starting to troll?
People with years of experience are trying to help you out and all the response they get from you is arrogance and evading posts. In one of them you do the exact opposite of what the other suggest youd do.
For your own sake, look at your robot more carefully and scrap a dozen or so of your attachements.
@All the others: Do not feed...
i am not being arrogant, i just think i should be free to make my own mistakes
