i would take x-terminator and make it competative again yet it will take a lot or fime and money to do it were as mr nasty would be ready to run and since its 6mm steel, i doubt it would need changing to hardox armour
yeah, as far as I know all that would need changing would be the radio system and possiblly the batteries (im not sure what it uses)
Ahhhh I see, didn't know that. The conversion should be fairly straight forward, just a case of pulling all the old stuff out and putting the receiver in instead. If you're using the older speed controllers, NCC boards I think it is, you will need to keep the receiver battery too. Just so that doesn't become a problem :)
EDIT: From the pictures it looks like Mr Nasty is using 3 SLA batteries :)
36v, 4wd, 4 bosch 750's rammer
if RR allow slippers again, i would do a pussycat style spinner in 10kg... possibly :)
not sure if there would be enough space for a disc, Mr Nasty looks quite compact, personally I'd put a tornado style scoop on the front
If you wanted to swap the SLA's for NiCad's you might have the weight for a spinner, but the space would probably be the biggest issue. The scoop would work a treat, probably a better use of the spare weight.
. :lol:Quote:
Have RR banned you from wearing your slippers?!?! the monsters..
lol, funny :lol:
thanks for pointing out my typo tony ;)
but a double wedge with a spike on wither would work :)
yeah, I'd probably try and make the scoop interchangable so other weapons could be put on.
interchangable with what though??????
