Pussycat Tribute Tournament 5
Virtually every idea has been done at least once, if not on the FRA forum, on the old Robot Wars Forum or on the old Panic Attack Forum. There is a finite number of weapons you can have on a robot, and we are getting near that number.
In terms of the Daniel vs. Martyn weapon stolen case, according to the good old history books of business, Daniel acted before Martyn, even though Martyn had the design on his computer, he didnt lets say patent it, and so Daniel comes along, probably knowing about Martyns design, but he posted it first and should get all the credit. (Well, looking at the woobler weapon itself, isnt truly new, because Chalkie 3G has an option for one to get under skirts, but thats not truly orginal)
The same happened with the old old crap circle of life with its loose ring to stop spinner attacks, but I forgot about it until revising the design.
So, the point of this post is...
...Eat Pie:)
Woo, 800th post
That ice armoured robot never happened you hear me! lol
You mean Heart of Skandi? Even if it didnt work, it was extremely cool:proud:
Hey Hey, Im Dazed and Confused, here is HHISTWT to replace one of my machines.
Name - HHISTWT
Shorten Name - Hey Hey
Shape - Low dome, spinning bar, crown top
Weapon - Simple spinning bar, angled downwards at the ends to hit those 8 cm robots, but the tips at their lowest point is 6 cm, the bar spins about 1300 rpm, and is geared to be torquy. The power source is an IC engine from a Flymo Lawnmower, giving 4.5 horsepower with high torque and bullet proof construction. I will give more details on the IC engine if needed. The only change to it, is the removable of the petrol tank to a more suitable location, and oil seals so it can run upside down if needed, and replacing the pull-start is an electric-start I nicked from a larger lawnmower. Direct drive with heavy-duty clutch to drop power if needed. The engine is sitting above the bar (like Amp)
Armour - It has a steel inner-ladder chassis framework, where everything inside the main dome is bolted/welded to. There are some lead-weights to counter-act the weight at the top to create a low centre of mass. The underside is 3mm steel. The dome is ABS plastic formed, with 3mm ABS plastic, with added wood ash into the mix before it set, creating a strongish shell, but not that strong. The bar itself weighs 22kg, with a 3 kg counter-balance in the centre to create a virtually uniform bar. The crown on top is designed to stop axes and crushers, and is lots of thin titanium strips layer on top of each other to make it very hard to break though. the advantage of this is the self-righter as well.
Ground Clearance - The bars lowest point is 5cm, so all around the robot is a 4 degree skirt, adding like a wedge. The skirt is removable for a standard 15 degree skirt, for those annoying machines. Under the main body is a good 9mm ground clearance.
Drive System - The robot is small and compact, because under that ABS shell, lies the drive system from Chalkie 3G, pushed together some more to create 8 wheel drive from 4 motors. This system gives a good speed and acceleration, but thanks to the small wheels, crap torque. Everything is cooled using a PC style cooling system.
Self-righter - The crown gives a roll-over shape and stops the robot from landing on its side. If the robot lands right onto its top, the crown crushes under the force after 5 seconds, and it rolls onto its side, where it should come back onto its wheels.
Velocity, Acceleration - 20 mph top speed, gets their within 2 metres.
Tyres - Sticky solid rubber tyres and steel wheels. Can run without rubber. There is one motor for two wheels, which are linked like a cars brake system, so if one motor goes it still has equal number of wheels moving on one side.
Weight - Dont Ask me about weight, I have no idea on what it will weigh.
Summary - Nothing New, Old-school technology, torque spinning bar. Based loosly on the American Amp in terms of its overall design. The Flymo lawnmower I stole the motor from never failed, and the engine restanded stone hit after stone hit. It runs at a higher power to turn the heavier bar. Its simple bread and butter.
Advantages - Torque from engine giving enough torque to the bar to keep spinning no-matter what it hits. Low centre of mass thanks to blocks of lead.
Disadvantages - Where should I start? - The horsepower from the engine is low, the drive system has low torque to push back, but high traction due to the grippy tyres. The body shell and crown are strong, but not that strong.
Hopefully Hey Hey is okay, I was bored during an exam and penciled a design on some extra-paper.
Id tell you, but then Alex would have to kill me. OK, hes probably planning on doing that anyway, but I see no reason to give him incentive to accelerate said plans.
A few things I forgot to say.
Hey Hey is replacing Wafty in the heavyweights.
Before Toni (:proud:) picks up a fuss about it being a semi-clone of Amp, I have ask permission from Paul^2 and he says I can use the basic idea of motor on top, spinning bit in middle, small and compact chassis.
and Frank drinks a lot of coffee :proud:
Y damnit!
Also, why should I give a care if its based off of amp? For the eitheenbajelienth time, im gone from ARC.
The Amp design is just a rip off of GreenWave, ICEWave(http://www.buildersdb.com/botpics/2391.jpghttp://www.buildersdb.com/botpics/2391.jpg) and Lumber Jack :proud:
So why ask for permission from someone else who already ripped the design :proud:
Im posting this for Steve for Aaron. Right.
Fragmentor
Motivation: 2WD
Speed: 15MPH
Weight: 100kg
Height: 200mm
Length: 650mm
Width: 750mm
Weapon: 15kg Flywheel powered by a Honda CR125 Motorbike motor. The CR125 motor produces 42.3BHP @ 11500rpm, it also has a HTI 220w 12v geared starter motor attached. The flywheel spins at 4500rpm producing 80Kj€™s of kinetic energy, plenty to dint and tear small pieces out of Hardox, rip holes in titanium and carve aluminium like paper. Spins up to full speed in under 3 secs, plenty of time to spin up between attacks.
Drive: 2 x Lemco 130 motors under volted at 24v to produce a zippy and moderately torque filled drive.
Batteries: 24v @ 6amp NiCD Packs
Armour: 4mm Hardox 400 on the sides/front/back, 8mm Titanium on the top and bottom and 15mm Polycarb internal bulk heads
Notes: Extra heavy mega duty shock proofing against it€™s own weapon. Uses a Gyro to stabilise the drive. Invertible.
Advantages: Fast drive, powerful weapon, moderate armour and well controlled
Disadvantages: Not a mega pushy bot, spins like Warhead when it hits an opponent.
Gyrate
Shape: Wedge with sloped sides, ala Wee Willy Wedgie
Motivation: 2 inner wheels
Speed: 50MPH
Weight: 100kg
Height: 250mm
Length: 550mm
Width: 650mm
Weapon: Static Wedge, a thwack tail on the end with a 5lb hammer
Drive: 2 x Eteks on 48v geared 4:1
Batteries: 160 x 3600mAh NiCD cells making 48v @ 12amps
Armour: 8mm Stainless Steel...... oooohhhhh Shiny!
Intensity
Motivation: Wheeled
Speed: Low gearing @ 12.889KMH(7.8MPH), High gearing @ 53.69KMH(33.55MPH)
Weight: 96.10kg
Height: 95mm
Length: 840mm
Width: 915mm
Ground Clearance: 8mm under body, 0mm all the way around due to Hardox skirting
Weapon: The weapon is based on the Team Whyachis Red Square which is a torque spring tensioned and suddenly released with a coupling to a flipping mechanism. The torque spring method used in Intensity is much more simpler and more reliable then the one used in Red Square. The mechanism is two S28-150 Magmotors @ 36v geared 100:1 through a single stage 3:1 spur gearing which is connected to a dual stage planetary gearbox which turns the final output helix spline shaft to retract and tension the spring. To lock the spring, a solinoid locking rachet has been built into the final stage of the planetary gearbox, which holds the spring tensioned till the solinoid is activated and releases the hold on the helix spline thread allowing it to unspool and fire the flipper. The torque is very heafty and with the flipping ratios will flip with a final force of 450kg, enough to send a 100kg robot head over heals quickly. The flipper takes 1.4 seconds to rectract and be ready for a second shot.
Drive: The drive consists of 8 Dustin motors. Each motor is over volted to 36v which produces 2.26HP per motor. Due to running the higher voltage, the motors have been current limited to 120amps which reduces the motors to 1.5HP each, producing a significant 12HP combined. The Dustin motors based upon the Dewalt Hammerdrills have a two speed gearbox, a low gearing of 51:1 which will make travel at a slow but high torque 12.88KMH(7.8MPH) which is enough torque to push the best of pushybots, in the high gearing of 11:1 will boost Intensity up to landspeed record of 53.69KMH(33.1MPH) with a loss in torque in pushing, but will still have the power to push most bots around running on basic Magmotor drives and Bosch setups.
Batteries: 8 x 18v 3600mAh NiCD Battlepacks producing 26v @ 14400mAh supply (Enough for 10mins of solid driving, plus weapon activation)
Monocoque (Chassis/Armour): The monocoque (chassis & armour combined) is a fully welded Hardox 500 5mm chassis (base plate is Hardox 450 3.2mm to maintain ground clearance). The top covers are bolted in using a series of 12 M14 bolts per top plate. This monocoque is designed to take a pound from the sides, above and even below! This is the heaviest part of the robot, due to the extreme strength and protection in the construction.
Electronics: Runs a RoboWars.org BMC speed controller with Hitec Focus SS-3 75mhz PCM 3ch Radio and a 3-axis computer Gyro for maxium control and handling. Uses 150amp rated Anderson power pole connectors and locking pins. Electronics are shock mounted and mounting in a floating style encased in HD (High Density) foam.
Notes: Can selfright via the torque spring flipper. Invertible!
Weight Distribution:
Batteries = 9.6kg
Drive Motors = 10.4kg
Wheels = 2kg
Magmotors = 3.6kg
Spring Mechanism = 12kg
Monocoque = 42.68kg
Electronics = 2kg
Flipper Plate & Supports = 8.5kg
NutsnBolts + Others = 6kg
Total = 96.10kg
Mass Disctruction Ultimate 3
Motivation: Wheels
Speed: 12MPH (480MPH Tip Speed)
Weight: 100kg
Height: 250mm
Diameter: 800mm
Weapon: The robot itself is the weapon. It uses its drive and a custom made micro processor system similar to that used in a fellow translational spinner called Cyclone Bot to translate itself around the arena creating a €œVortex of Destruction€Â. Using 9 Hardox €œenlightened€ teeth, it tears its opponent to pieces when the teeth collide at a sub-sonic speed of 480MPH. Causing certain death to the opponent.
Drive: 3 x Briggs & Stratton Eteks running on 60v. The motors are protected with a current limiting circuit and a thermal protection system which will ensure the motors don€™t over heat. The drive system uses a unique variable drive system with load sensing technology which enables the robot to start rotating with a high gear ratio preset at 5:1 giving the motors high torque low speed. As the robot gains rpm, which is constantly monitored via wheel rpm sensors, the gearing then adjust to suit the load of the motors and gain further speed allowing the gear ratio to lower from 10:1 to as low as 1:1 at top speed. The gear ratio can also over drive thrown the ratio 1:2 giving the robot nearly double the original top speed and allowing far more energy, but this is only used when the opponent is at a distance where it can easily be disposed of. Otherwise, the drive is left at 1:1 maximum.
MDU 3 sports an advanced drive control system to that of Cyclone Bot as it uses motor and wheel sensors to travel and translate in the most efficient possible way, minimising energy lose. The drive will adjust ratio to suit condition if it is loaded and will change if need to translate at the full 14MPH (6MPH up on the last version since the robot size has decreased for faster movement, quicker spin up times and thicker armour). Spin up time is minimal and varies between 0.5sec spin up and 1sec when the system is suffering from battery voltage drop. At a mere 1/7th of its full RPM, this robot will be dangerous. 500rpm will have enough energy to throw robots out the road and allow it to continue it quest for domination. If people start ganging up on it (Everyone will, I know), the drive system will be locked down into 500rpm mode allowing the drive to have nearly maximum potential torque yields and it will force the opponents away till it can then safely power back up to full speed and deliver the force of the €œVortex of Destruction€Â. To ensure endurance during combat, everything has been shock mounted for maximum protection.
Batteries: 250 x 3600mAh NiCD cells producing 60v @ 18amps. The packs are protected by a system like the drive which give both current and temperature protection. The packs are re-enforced between the cells with Polypropylene cell holders and will prevent them from breaking during the impacts.
Armour: 4mm Hardox 500 with stainless steel welding built in a monocoque design with triangle shape and inner supportive bulkheads. 10mm Polycarbonate on the top to save weight due to the upgrade to Etek motors and higher voltage
Notes: Invertible. Soon to be your worst nightmare. All within your precious 100kg weight limit. Approche Avec prudence.
Rogue
Motivation: Wheeled
Speed: 18.84KMH (11.775MPH)
Weight: 91.39kg
Height: 248mm
Length: 523mm
Width: 1040mm
Ground Clearance: 10mm under disc teeth and increases to 20mm at the back.
Weapon: The weapon is a 24.61 kg, 580mm (From tooth tip to tooth tip) diameter flywheel mounted on a 20 degree angle. The flywheel is powered by a 6.8kg 125cc 5.3Kw (7.06HP) Husqvana chainsaw with modified Astroflight electric starter motor. The chainsaw has a peak RPM off 8500rpm and is geared 3.4:1 with a kevlar innerbound belt drive to produce a flywheel speed of 2500rpm. The chainsaw has a centrifugal clutch that prevents the flywheel from spinning at idle and prevents the chainsaw from stalling by cutting out at 500-600rpm. The weapon has a tip speed of 273.14Km/h while producing around 32Kjs of Kinetic Energy. The teeth are based on a shark tooth design where a inner concave to cut though metal much quicker and easier. The teeth are CNC machine blocks of Hardox 650 Wareplating to maintain a near perfect cutting edge.
Drive: The drive is a pair of S28-400 Magmotors coupled to a pair of 8:1 aluminium planetary gearbox which gives a final output speed of 500rpm at the drive shaft. The wheels are 200mm (8inch) Colson wheels with 3.25 mm Hardox 450 protection plates and 8mm thick Grade 5 Titanium/Vandium domes with tip spikes. The wheels are mounted on 40mm hollow, 5mm wall Stainless Steel shafts for maximum strength.
Batteries: 2 x 24v 3600mAh NiCD Battlepacks producing 24v @ 7200mAh supply (Enough for 10mins of solid driving, 8 mins of driving with several motor starts)
Monocoque (Chassis/Armour): The monocoque (chassis & armour combined) is a fully tig welded 8mm thick Grade 5 Titanium/Vandium with support braces and inner bulk heads for maximum strength and rigidness.
Notes: Can selfright via off balance weight distribution whe upside down and is added by the contact of the flywheel on the floor.
Disc = 24.61kg
Wheels = 4.21kg
Chainsaw = 6.8kg
Chainsaw starter motor = 1.6kg
Gearboxes = 5.6kg
Batteries = 2.46kg
Monocoque body = 24.81kg
Weapon mounting and weapon drive components = 4.1kg
Electronics = 1.2kg
Drive motors = 6kg
NutsnBolts + Other pieces = 10kg
Total = 91.39kg
The Ultimate Wedge
Motivation: 6WD
Shape: A wedge shape like Voltronic
Speed: 35MPH
Weight: 100kg
Height: 250mm
Length: 800mm
Width: 600mm
Weapon: A High Pressure top hinged flipper powered by a 80mm bore with 3 20mm Burket valves feed from a 3L buffer tank, using 2.2L of Liquid CO2. Well over 500kg of flipping force. This is not designed to be a big powerful flipper, but is used to launch the opponents over the arena wall or to momentarily disable them so they can be rammed again! Flipper sits on top of the armour, meaning when the flipper fires, the robot is still armoured everywhere.
Chassis/Armour: 4mm Hardox 400
Drive: 2 x LEMCO 200€™s! Bigger then the LEMCO 130€™s and they put out more HP!
Batteries: 160 x 3000mAh NICD to produce 48v
Notes: The robot is invertible.
Advantages: The SPEED! The Pushability! The Strength! Flipping good
Disadvantages: Having to keep your opponent in the arena long enough to have fun
Mother of All Bricks Inevitably Evolved
Motivation: 4 Titanium wheels with urethane rubber and NIB magnets inside the rubber for extra traction on metal floors.
Speed: 15MPH
Weight: 100kg
Height: 220mm
Length: 650mm
Width: 620mm
Weapon: An active electric wedge, works both was up and is primarily used to get under the opponent and allow the drive to show them the walls.
Drive: 2 x LEM200D motors producing around 52HP peak each when on there nominal 60v. The motors are current limited to 400amps, which limits the constant HP to 35HP combined. The motors will be run at 59.2 volts
Batteries: 16 x 3.7v 40000mAh Lithium Polymer cells producing 59.2 volts @ 40amps. The Lithium Polymer will give continous amperage of 5C(200amps) and peaks up to 10C (400amps)
Armour: 6mm Hardox 450 all over
Notes: Invertible
Particle Accelerator (FW)
Motivation: wheels
Speed: 8MPH
Weight: 12kg
Height: 80mm (Excluding weapon motor height)
Length: 380mm
Width: 380mm
Weapon: 3.8kg spinning shell powered by a 35cc Huski chainsaw geared 5:1 down to 2000rpm. Spin up times should be less than 2 seconds with the motor screaming all the way!
Drive: 2 x 12v GMC 2 Speed drills with 75mm wheels.
Batteries: 10 x 2000mah NiMH producing 12v @ 2amp. Just enough to last a battle and a bit.
Armour: 3.25mm Hardox rim, 3mm Titanium top, 2mm Titanium base plate.
Notes: If you€™ve seen ICEWave, you€™ll understand this puppy. Pictures is a tad wrong, it€™s missing the motor, gearing and has two many packs in it :P (Was designing a EV powered version for this as a real featherweight)
The Quick & The Dead (LW)
Rule Bending Cluster Bot!
Motivation: 4 Wheels
Speed: 18MPH
Weight: 6kg
Height: 75mm
Length: 300mm
Width: 450mm
Weapon: A barbed wedge. Drives under the opponent and they get stuck on it! W00tage!
Drive: 2 x 12v Thin Gaps with NPC gearboxes
Batteries: 10 x 2600 NiMH producing 12v @ 2.6amp. Enough for 5mins hard driving
Armour: 5mm titanium monocoque with 10mm polycarb inner bulkheads.
Notes: Invertible, speedy wedge with one purpose. Getting the opponent stuck!
Motivation: 12 Legs
Speed: 1.89MPH
Weight: 19kg
Height: 250mm
Length: 600mm
Width: 600mm
Weapon: 8 tonne hydraulic crusher/ electric lifter combination. The weapon takes 0.5 seconds to close at full speed, due to the Vivoil twin speed pump and then a full 12 seconds to produce 8 tonnes at the tip. Should be able to crush up to 5mm Titanium, in around 15 seconds. Uses a variable ratio crushing mechanism, which is detailed in the attached drawing. A small linear actuator (250kg of force) is also mounted to the mechanism which will lift the opponent off the ground once the crusher has a hold.
Drive: 2 x 100w scooter motors on 48v (therefore 400w of power) while powers the legs. Leg mechanism shown in detail
Batteries: 40 x 2000 NiMH producing
Armour: 5mm 5083 Aluminium monocoque with Titanium & Hardox Exo-skeleton, refer to drawing.
Notes: Waits for €˜The Quick€™ to wedge/snare the opponent, trundles over and the crushers nice big holes into the opponent.
Insomniac (MW)
Motivation: 3 Omni wheels
Speed: 12MPH
Weight: 50kg
Height: 150mm
Length: 600mm
Width: 600mm
Weapon: 3 x 300mm 5kg flywheels at 4500rpm, powered by a Perm 080 @ 36v.
Drive: 3 x S28-150€™s @ 36v geared 17.5:1 via planetary gearboxes to the omni wheels.
Batteries: 90 x 3600 NiCD producing 36v @
Armour: 3.25mm Hardox, 3mm Titanium & 10mm Aluminium
Notes: Based on one of my first Vapourbots, Trifecta. Being an omni-bot, this little baby can run sideways and will cause a real fuss€¦.
Gyrate Extreme (SHW)
Motivation: 4 x Omni wheels
Speed: 10MPH
Weight: 155kg
Height: 320mm
Length: 500mm
Width: 1500mm
Weapon: The weapon is the focus on the robots upgrade. The 45kg spinner bar/hoop combo is powered by two Honda CR125 Motorbike motors. The CR125 motor produces 42.3BHP @ 11500rpm, and only weights 14.8kg each. The motors have a pair of electric starts mounted on them. The weapon rotates at a crazy 4500rpm, via a variable belt drive that changes ratios from 10:1 through to the final 2.5:1 ratio. The variable belt drive works by the expansion of one pullie (Motor end) and the contraction of the other (Weapon end) This is done via torque springs mounted on the adjustable pullies and forces them to change size when the load changes. Commonly found on 6WD amphibious ATV€™s.
Drive: 4 x LEM 130€™s on 24v geared 10:1
Batteries:
Armour: Can you say 15mm Poly-Propylene?
Notes: The weapon is devastating. The power is phenomenal. The noise is incredible! The bot is not invertible€¦ Flip and gone€¦€¦ But you have got to get close to it to flip it!
