Dont the arms have to be bigger than the body so he can hit things with them?
Looking at the stats, Joey, I believe the arms are attached to the side of the body...
thats uneeded luxury Joey
The picture would seem to indicate that theyre SOW style...which one is it?
SOW Style
Thats 46cm from the center
1cm reach? That might not be enough...Id increase it to at least 50cm.
Spinners are generally buggers to design because of the extra info you need to provide - you need things ike weight, how it stops itself self destructing, kilojoule count, etc. and it might be easier to do a rammer or similar as your first vapour, if youre not familiar with vapourbot stats.
Joey pretty much summed it all up. Start with a rammer, theyre much simpler and easier to do than spinners.
okay stats on a rammer up soon
Really, Ben, take your time when coming up with stats. You might want to decide what parts are best, what armour, wheels, motors, etc. Do some more research, as it will better your stat-making skills. :)
