How Could I Improve...
Ben. Quite honostly, those stats are not bad at all. But you have entered the pitfall most vapourboteers that start have fallen into, you keep your robot way to small. 4 motors, 4 battlepacks (which is to litte I would suggest 6), all the mechanics and the wheels, all take up space you dont have in a 45cm diameter robot. I have a featherweight that big.
i will improve the body to 75cm and the arms to 85cm
No no no, the arms are way too big, and the body still seems a little small to me...and you dont even give a height. :proud:
fine arms are 92 body is 90 and it is 15cm tall
My new vapour: Fling. :)
http://strickenone.proboards99.com/index.cgi?board=teambv&action=display&thread=350&p age=1http://strickenone.proboards99.com/i...isplay&thread= 350&page=1
Commence thy nit-picking! :proud:
Well one thing from the start, a Red Square type weapon will not work with a 5mm Ti bar. You would need at least 2cm thickness to achieve the tension needed (and i do stress at least). I believe Red Squares flipper bar was 1 inch (2.54cm) thick.
What do you use as a winch?
quote:
fine arms are 92
I tell you to make it smaller, QUITE clearly...and you make it bigger.
I can see where my advice is going. :lame:
they have to be half the size of the body my bad
so they are 46
so they are 46Erm...why do they have to be half the size and NOT less? Tell me please...
