First one comes with a 24v coil (me 14v( can a 12v coil work with 14v?) and second one maybe
yes you can use a 12v on 14v. the second one should be fine. after you,ve bought just send them a message saying you want the 12v version.
Ok thanks get that done soon !
Does anyone know where to get a regulater from?
* Working Pressure: 1.5 - 8 Bar
* Maximum Pressure: 10 Bar
my bars is going to be 10 so... maybe not
i'm gonna be running on 10 bar with it, will be interesting :crazy:
HAHA !!!!
good luck :shock:
Originally Posted by jonny
tell me how it goes hoplfully well :?
and my cylinder is max psi 145 and i am using it at 144 so........
Theo
back to regulators,
the ones on tecnobots## have a high(ish) flow rate but a low pressure rate (only 7 bar max outlet and a 10 bar inlet)
##http://www.technobotsonline.com/1-4-...regulator.html
i need a regulator with bsp1/4 conections, dont mined on the flow rate but not to rubbish and pressure rate has to at least 10 bars outlet and 69/68 bars inlet... so Any ideas on were to get one?
I got a Co2/Argon regulator 60 bar inlet 10 bar outlet
Its pretty hefty thou :/
May have to pop the question to Borrow on long term loan the high flow regualtor out of Dominator II
where did u get it from? and how big?Quote:
Originally Posted by jonophilpott
the only prob with long term loan is that it would mean buying it forever and the peeps from Dominator II mite need it again so
