When you signed up Ben, you gave your email address to verify your account, that address is used to send pms to.
If you change your email address you can edit that address in your profile by clicking on Edit Profile in the top right corner.
+2>LET THE EYE OF THE ROBOT-SERIES 5 BEGIN!!!!
+2>Heat 1
ROUND ONE:
Intriguer (1) vs. Leviathan vs. The Grudge
Gabriel III (17) vs. Supreme vs. The Deer
+1>From Toronto, Canada, seeded #1, INTRIGUER!!
-1>Entered by Kody Kunz
The mysteries of this robot are best kept hidden - especially since it€™s the champion! This robot is an ulta-low box 10cm in height, coloured green and cyan, with two spikes at the front that act as a super low scoop using the surface area rule, is a powerful force, using 4 wheels coated with urethane rubber, powered by 2 x LEM130€™s at 48V, providing a bit more power than the 36V ones, as this robot has 24hp in its power supply. The axe on this robot is Titanium, with a 5cm long solid Hardox axe-head, diamond edged, designed to pierce Titanium no issue, and dent Hardox easily using 2 x 2.5kg CO2 bottles, both at a pressure of 250psi. The armour on this robot is 5mm Hardox, very hard to cut or dent. The champion is a force to be reckoned with, but with a 4-9mm ground clearance, it€™ll have to reckon with powerful flippers€¦
In E.O.T.R 1: Didn€™t enter.
In E.O.T.R 2: Didn€™t enter.
In E.O.T.R 3: Didn€™t enter.
In E.O.T.R 4: Used that axe to good work in Round One by hacking into Paralyzation, and with help from 21st seed Turbo Tails, was able to pit it. And then we were treated to the biggest shock in the series, as Intrigue faced off against 5th seed Black Panther Queen - they both exchanged axe blows, until Intrigue got its axe into the ABC armour of its opponent, it then powered the seed down the pit! 21st seed Turbo Tails proved a little tougher in the Heat Final, as it flipped Intrigue and attacked the base panel, but Intrigue stopped the spinning of the and then finally pitted the Scottish design! Big Nipper drove towards planning a victory against Intrigue in Round Four, but Kody€™s robot was able to bash Big Nipper€™s armour and push it down the pit, but in Round Five, we saw Intrigue€™s biggest surprise when 1st seed and reigning champion Kali had every reason to beat it, but Intrigue overcame it, grabbed on with the axe and confined the Champion to the pit! Following this, it took on twice Grand Finalist Storm 2, and beat it as well, via a pitting, before a bloody battle against newcomer Fire And Ice, a tracked rammer, who gave Intrigue a lot of hell, until Intrigue broke a track, leaving it immobilised, and making Intrigue the champion!
+1>From Bedford, Leviathan!!
-1>Entered by Danny Bailey
It comes from the deep, and has surfaced to cause pain for all. A low box shape, but with a arc-shaped rear to assist in self-righting, with a flipping scoop powered by 2 x 2.5KG CO2 canisters and double 80mm full pressure rams at 900psi, and should be able to flip around 1000kgs, and toss 300kg. The armour on the 45cm high box is a moderate 6mm Titanium for the body, but for the front scoop, it€™s a mighty 10mm Hardox, the ultimate armour for deflecting spinners, and the like. 4 x S28-150 24V Magmotors, 4.5hp per motor, giving 18hp in total, mean that this tracked machine can outpush a lot of machine due its its massive motor output onto seriously high-gripped tracks. Leviathan is a robot in the making, but its height means it could be easily OOTAed.
In E.O.T.R 4: Didn€™t enter.
+1>From USA, The Grudge!!
-1>Entered by Rurak De Leon
Crusing for a brusing to give its opponents, it€™s the Grudge - one of the scariest tracked robots around, armed with a massive €˜stinger€™ on top, powered by a 4€ bore, 12€™ stroke air cylinder at 200psi giving it about 2.2kj at end of swing, enough to cause serious harm. 18mhp is good for a tracked robot,, but if the tracks are hit, it€™ll be The Grudge after medical attention rather an revenge. That, and the 6mm Titanium is mediocre in vapourbot terms, so it may be torn to bits!
Booth #1: Ruark DL
Booth #2: Kody K
Booth #3: Danny B
Roboteers, stand by!!!
3€¦2€¦1€¦activate!!!
And E.O.T.R is off! It€™s a very quick and rampant start from the reigning champion, slamming off into the side of The Grudge, and the spikes on the front just slide under the clearance! Danny seems to be holding off slightly, but it€™s a wise idea, and Kody proves why Intriguer is the champion, activationg the axe! The 6mm Titanium looks like nothing, as the large heavy spike drives large holes into it! Ruark looked worried, but the judges tell Kody to back off, and now Rurak goes on the offensive, speeding down the ring, and attacking the front-right side of Intriguer€¦NO! An interception by Leviathan! And suddenly a spin by the robotic sandwiches - The Grudge between two forces, and VERY slowly the scoop of Leviathan slots underneath the clearance€¦AND THE RAM FIRES VERY QUICKLY!!! The Grudge goes spiralling up, doing 2 full twists in the air, as the audience woops Danny creation. Kody backs away, now allowing Leviathan to show its worth, attacking The Grudge from the rear, but Rurak fires the axe€¦NO! Danny€™s superior controlling skills allow him to dodge the axe€¦but now Intriguer is attacking again! Rurak is starting sweat€¦BANG! The axe punches through the top, and now the armour is beginning to crumbles here! The Grudge shifts a little€¦THE AXE FIRES! Nothing but a dint on the supremely thick 5mm Hardox shell protecting Intriguer, who is just pushing The Grudge back with near-to-no effort at all! The Grudge is slammed back hard into the spikes, cracking some of the low-mounted chassis bolts on The Grudge! Kody decides to deliver another axe-hit€¦BANG! Suddenly, The Grudge goes quiet - the final axe hit killing off the chance of The Grudge moving forward. The count begins, BUT IN COMES LEVIATHAN!
10€¦9€¦8€¦7€¦6 €¦5€¦
LEVIATHAN RAMS IN!! He bashes under and€¦FLIPS! A 360 FLIP AND OFF FLIES THE SHELL! The Grudge is OOTAed having been battered to the point of the shell breaking! Kody and Danny punch the air in delight, moving on to the next round!
Result:
The Grudge needs surgery more than a need for revenge!
INTRIGUER (1) AND LEVIATHAN GO THROUGH TO ROUND TWO!!!
+1>From Pontefract, seeded #17, Gabriel III!!
-1>Entered by Joey McConnel
Named after the €˜Angel Of Peace€™ in the bible, in the arena this robot is the €˜Angel Of Death€™! Gabriel is an elongated Triangular pyramid with a steep rear and shallow front end. Motors for this are 2 x LEM-130€™s run at 36V, driving two semi-pneumatic rear wheels with Vulkanised tyres for grip. The control is worth noting, as these two wheels are normally run as one with forwards/back movement, and a castor at the front is rotated via a custom high torque servo mechanism +/- about 75 degrees giving car type steering, however the robot can also be driven with the two rear wheels seperately in standard tank steering with the front castor being passive. This gives maximum controllability at both low speeds (16mph) and high speeds (30mph). It has 5mm Titanum body with 5mm Hardox edges, making the panels hard to tear off. The base is 5mm T6 Aluminium, and is quite resistant. It also has a very powerful front-hindged flipper and it is powered from 750psi CO2 stored in one 3kg tank, and a 80mm full pressure hydraulic ram with high flow rate giving about 20 uses in a fight. Also, the front point has spikes either side to cause damage by spinning, but these are now more blade-shaped than spike shaped, and made of hardened tool steel. Looks to be a contender, except in a pushing battle, where the shape will hinder it.
In E.O.T.R 4: Started off by teaming up on Bulldog Breed with then-champion Kali, bashing it around the ring, before getting in a sneak attack on Kali after Bulldog Breed was OOTAED. In Round Two, it took on veteran, 17th seed - the terrifying Terrorhurtz, but Gabriel V1.2 attacked and fought€¦and survived on a JD. But despite pulling off several good moves on Kali in the Heat Final, Gabriel soon hit the camera tracks.
+1>From Swansea, Wales, Supreme!!
-1>Entered by Daniel Stickler
Aiming for Supreme glory, Supreme is fighting it out here! Powered by 2 x S28-400 MagMotors, running at 24V, this 6mm Titanium armoured axe-machine is one to watch, with power output of 8hp and top speed of 15mph means it€™s quick, powerful and tough. This robot has wedges/skirts on its front and sides, and to protect the back is a VERY unique weaponry system - at the rear is a large 1m diameter spinning ring, made from 4mm Hardox. 75% of the spinning ring is hidden by the armouring of the robot, but the remaining 25% has been left exposed in order to act as a type of defence for Supreme, especially as the axe is a uni-directional offense weapon. The spinning ring houses all the motors, electronics and batteries, and weighs just over 30kg. The disc has 4 large 1cm thick Hardox teeth, each being 3 inches in length and 4 inches wide. The spinning ring is powered by a LEM130 Lynch Motor running at 36v, geared down 4:1. The motor can spin the ring at a top speed of 1000rpm, giving off an output of 37kj, which is transferred to the Hardox axe with a pure 7kg Aluminium alloy head to pierce Hardox with ease! Supreme could be one to watch
+1>From Keveldon, The Deer!!
-1>Entered by Martyn Forsyth
Oh dear, you may be in trouble if you face The Deer! This low invertible box shape, armoured in 3.6mm Hardox protection, with 4 wheels powered by 2 x S28-400 MagMotors at 24V, allowing for 9hp, and 15mph top speed. It€™s weapons are Titanium claws, made of Titanium and shaped like deer antlers, powered by hydraulics through a 120mm bore rams at 3000psi, giving 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The sides are skirted, but the front isn€™t and although the claws are at the front, The Deer may go flying.
Booth #1: John R/Samuel P
Booth #2: Kody K
Booth #3: Randy E
Both The Deer and Supreme, the 15mph machines, move out slowly towards each other€¦but the 35mph Gabriel III is like lightning! Gabriel seems to be targeting The Deer, and it smashes straight in between the claws! The Deer rides up the pyramid shape, now on the powerful flipper, as Gabriel continues to speed forward dangerously, edging closer to the edge€¦FLIP! The Deer just hits the wall, with Gabriel failing the OOTA attempt, and Martyn quickly running away from Gabriel, but Supreme is on his way in, AND DANIEL DECIDES TO BRING DOWN THE AXE! It misses, and slams the floor hard, as The Deer turns left around and hits into the side of Supreme, then CLOSING the claws around the Titanium body, and powering forward - BANG AGAINST THE BLUE DISC! Sparks fly off the 8mm Titanium skin of Supreme, even if it is supremely tough, pun intended. Gabriel just seems to be watching, waiting almost for Supreme to respond to the hit, which eventually he does, then spinning to attack The Deer! Gabriel charges at The Deer€™s rear side, but for some reason, the pointed front isn€™t getting underneath, and The Deer continues the crush into that 8mm Titanium! Supreme is hammering away at the floor TRYING to escape - but he€™s unable to, as the team-up on Martyn fails - Supreme is pushed straight across the arena, towards the pit€¦BOOOM! Out goes Supreme!
Result:
Supreme€¦like heck!
GABRIEL III (17) AND THE DEER GO THROUGH TO ROUND TWO!!!
ROUND TWO:
Intriguer (1) vs. The Deer
Gabriel III (17) vs. Leviathan
Tactics, predictions, comments, and a relief for getting this done :proud:
Garshp! It moved!
*dies*
Im sensing a distinct Please, Kody, just shut up about it feeling about this from what Ive heard on msn and on here :proud:
Nevertheless, w00t for me winning and for a fairly good fight...against Leviathan, tactics are basically to flip it a lot and use common sense.
IT LIVES!
Oh, and I ish very persistent. :proud:
Wheels. Kill em. :proud:
I see Gabriel taking a tumble down Mr. Pit.
Now lets see some consistently posted fights Paul. :P
And...you still didnt give us a reason why you delayed the fights, lolquote:
Well...I have been concentrating on school stuff, as Ive just finished my 9th year and moving into Year 10. So Ive been concentrating on that, and Ive been working on a private writing project and not putting full focus on E.O.T.R.5, and I was also wondering what happened to Rurak, as he came and he went, and I dont know what he wants to do in the fights, so Im not too sure on that area.Rubbish. im in college and I still find time to post fights. :proud: As for Ruark...dunno. :S
(Message edited by kodster on October 14, 2008)
It was a combination of school (gone into the BIG year :proud:) family issues and personel issues, but now Im back on course now:proud:
Okay, but why didnt you tel us before? :sad:
IT LIVES ??!!
Good fights Paul, glad to see this moving :)
w00t for me winning and for a fairly good fight...against Gabriel, tactics are basically to flip it a lot and use common sense.}
Paul, no offense but i wouldnt call year 10 the big year, even by secondary school standards, year 11 is the key year. However there are people on this forum who are in much higher and more important academic years than you and still manage to be more active than you have been recently.
