Spektrum DX6i / BR6000s
I assume youve selected the correct mix and the controllers havent an onboard mixing function.
So...you may have a MODE 2 transmitter ( right stick Ail and Ele ) that is set as Mode 1 ( right stick Ail and Throttle )... anyway its worth a quick try.
SWAP a plug over on the receiver ...take the one from Ele and put it into the Throttle channel.
You could also check that the reciever channels match the transmitter stick with a servo ...after switching off all the mixing.
Suren had a similar type prob recently on his secondhand Spektrum transmitter and the Mode didnt match the Transmitter sticks.
(Message edited by woody on November 26, 2008)
I am not sure if the DX7 is the same as the DX6i but on that I use.
MIX1
ELEV + AILE ACT
RATE L -100% R -100%
SW ON TRIM ACT
MIX2
AILE + ELEV ACT
RATE D +100% U +100%
SW ON TRIM ACT
perfect Pete as usual, I didnt know it needed 2 mixers but once i set up mix 2 its perfect
cheers Pete
What is the latest on the dx6i problem front.Wendy needs a tx for her featherweight and is not sure weather to go for dx5,dx6 or dx6i.Advice please
Best combinations in random order:
DX6 and BR6000
DX5 and AR500
DX6i and AR500
All three combos work as required for failsafe.
Possible DX6i pot issues...
http://www.horizonhobby.com/Articles/Article.aspx?ArticleID=1885http://www.horizonhobby.com/Articles...ArticleID=1885
Interesting... I saw a new Robbe transmitter with a similar issue just the other day!
